What product do you wish to discuss? QingPing CO2-TEMP-RH
What firmware version? 1.3.1
Computer OS? (MacOS, Linux, Windows) Windows
What Computer OS version? Windows 11
How often does the problem happen? Always
How can we replicate the problem? Yes
I am using the QingPing Decoder in the TTN, but it has a problem, because I am receiving a error message: “TypeError: Cannot read property ‘toString’ of undefined or null at Decoder”
"name": "as.up.data.decode.fail",
"time": "2024-06-13T19:16:46.465691117Z",
"identifiers": [
"device_ids": {
"device_id": "co2-temp-rh-001",
"application_ids": {
"application_id": "co2-temp-rh-nasondas"
"dev_eui": "D896E0EFFF000141",
"join_eui": "D896E0EFFF000000"
"data": {
"@type": "type.googleapis.com/ttn.lorawan.v3.ErrorDetails",
"namespace": "pkg/scripting/javascript",
"name": "script",
"message_format": "{message}",
"attributes": {
"message": "**TypeError: Cannot read property 'toString' of undefined or null at Decoder** (<eval>:7:25(15))"
"correlation_id": "61010a4845f04a90acb2e8cec54f7da5",
"code": 10
"correlation_ids": [
"gs:uplink:01J09GFWH95B0N0RPRSTYJXXE1"
"origin": "ip-10-100-7-59.eu-west-1.compute.internal",
"context": {
"tenant-id": "CgN0dG4="
"visibility": {
"rights": [
"RIGHT_APPLICATION_TRAFFIC_READ"
"unique_id": "01J09GFWR1YRJKHXYQW78VQXV3"
This is the Decoder that I am using in the TTN:
function Decoder(bytes, port)
var decoded = {};
var deviceAddress = bytes[0].toString(16).toUpperCase();
var reportCode = bytes[1].toString(16).toUpperCase();
decoded.deviceAddress = deviceAddress;
decoded.reportCode = reportCode;
var dataLength = parseInt(bytes[2].toString(16), 16);
decoded.dataLength = dataLength;
var dataType = bytes[3].toString(16).toUpperCase();
decoded.dataType = dataType;
if (dataType === "1") {
var timestampBytes = bytes.slice(4, 8);
var timestamp = bytesToHex(timestampBytes);
decoded.timestamp = timestamp;
var temperatureHumidityBytes = bytes.slice(8, 11);
var temperatureHumidityHex = bytesToHex(temperatureHumidityBytes);
var temperatureHumidityValue = parseInt(temperatureHumidityHex, 16);
var temperature = ((temperatureHumidityValue >> 12) - 500) / 10;
var humidity = (temperatureHumidityValue & 0xfff) / 10;
decoded.temperature = temperature;
decoded.humidity = humidity;
var co2Bytes = bytes.slice(11, 13);
var co2Value = parseInt(bytesToHex(co2Bytes), 16);
decoded.co2 = co2Value;
var battery = parseInt(bytes[13].toString(16), 16);
decoded.battery = battery;
var versionCodeBytes = bytes.slice(14, 20);
var versionCode = bytesToHex(versionCodeBytes);
decoded.versionCode = versionCode;
var crcBytes = bytes.slice(20, 22);
var crc = bytesToHex(crcBytes);
decoded.crc = crc;
return decoded;
function bytesToHex(bytes)
var hexArray = [];
for (var i = 0; i < bytes.length; i++)
var hex = (bytes[i] & 0xff).toString(16).toUpperCase();
if (hex.length === 1)
hex = '0' + hex;
hexArray.push(hex);
return hexArray.join('');
Could you help me?
Claudio
