Hello all, does anyone know if it’s possible to swap the RAK3401 Core and RAK13302 1W LoRa Booster over to the RAK19001 Dual IO Base board? I’d like to build a Meshtastic node that has the 1 Watt power and PoE Ethernet (RAK13800/RAK19018), but it appears that nothing is detected in the second IO slot.
Seeing as the 1W Booster Kit is pretty new, will dual IO be supported with the RAK3401 Core in the future? Or, is there a different Core or Base I should be using to get dual IO slots?
Ah, okay. I’m still pretty new with the WisBlock ecosystem and hadn’t seen that tool yet.
I’m guessing the conflicting SPI and GPIO is a physical design choice and can’t be easily changed, and there’s probably no plans at this time to make a compatible RAK13800?
So I also was interested in this and have already received parts. If I accept the fact that I cannot utilize both IO modules, but if I have both installed (1W in Slot A, Ethernet in Slot B) will there be conflict? I suppose so, mostly because of the SPI CS. I would really like to power this node over PoE (not having ethernet data is acceptable), but I am not sure that will be possible with the 1W installed.
