Hi, I have a RAK5860 that is going to be connected to my RAK19007 baseboard and RAK4631 CPU. I have a couple of questions of the best way to configure this module.
Are there any limitations which SIM cards can be used with this module or will any SIM/ESIM work?
I can’t say much about RAK5860 since I do not have here LTE-M and NB-IoT coverage in my place.
However, some thoughts I can share to you:
We cannot say all Sim cards will work. It depends on what network is available to you and how you can connect to the telco you are trying to connect. I did some experiment with RAK5860 few years ago with our Local telco with ther NB-IoT (test network not yet public) but I cannot connect to it. However, using our RAK5010 with GPRS works fine since GPRS network is widely available in my place. If you have other working Cellular module on the type of network you want to connect then there is a good chance you can connect to it.
APN configuration depends on your Telco provider or on the global SIM you use (if you use one). IoT Sim like monogoto or hologram has APN configuration in their guide/website.
MQTT is a lightweight protocol and widely use in IoT than HTTP. This is a matter of preference on the developer side. HTTP is widely adopted in the internet itself but if you will dwell with IoT, it is worth pursuing to use MQTT since likely this is the type of communication protocol that you will frequency see in the IoT space.
Hi @carlrowan , thanks for the answers. Are you aware of if this module is required to specifically use an IoT sim card or IoT esim? For example, is it required to use a Sim Card like one from Hologram which calls itself an IoT Sim?
I also am still trying to figure out how to configure an eSim in the example codes to work with the RAK5860 module when attempting to connect to cellular, in case anyone out there has done this before
in my experience SIM cards for mobile phones don’t work for NB-IoT. So yes, you’ll need an NB-IoT SIM card like the one from Hologram. Make sure you chose a SIM card which covers your location and desired service type, e.g. NB-IoT / LTE-M1.
From what I understand the eSIM IC is not populated on RAK5860.
"SIM Card Circuit The RAK5860 module only supports the 1.8 V ESIM/SIM card. Figure 12 shows the SIM interface circuit. By default, a Nano SIM card is used, and eSIM is not mounting. To offer good ESD protection, a TVS diode array is added to the SIM card circuitry."
