I am working on setting up a RAK 10701 device to work with AWS IoT Core for LoRaWAN. I believe I have sorted out the specifics for making it work, but I would like to know if there is any way to disable the QR code to the dev.disk91.com link after the scan is complete as I do not plan to integrate with this backend.
This is possible but you have to customize the firmware not to display the QR code. There is a function called showQRCode() that you can remove or replace with basic text like “Discovery Mode” done.
