I am trying to set up the 10701 through a 7289C GW to TTN by following the TTN instructions in the RAK manuals (run through it multiple times to be sure).
I can see the 10701 uplink in the GW packet logger and in the TTN gateway Live Data and (EDIT) after correcting cluster locations/urls for my location can get the appliction showing some activity, However I never see any data come through and on the device itself it never shows any connections. It simply states joining and failed. Live data from device in TTN asw below
• arrow_downward 22:46:09 Downlink successfully transmitted Rx1 Delay 5
• arrow_upward 22:46:06 Forward join-accept to Application Server
• arrow_upward 22:46:06 Forward join-accept message
• arrow_upward 22:46:06 Receive join-accept message
• arrow_downward 22:46:06 Successfully scheduled join-accept for transmission on Gateway Server
• arrow_downward
22:46:06 Schedule join-accept for transmission on Gateway Server Rx1 Delay 5
• arrow_upward
22:46:04 Successfully processed join-request
• arrow_upward 22:46:04 Join-request to cluster-local Join Server succeeded
• link 22:46:04 Accept join-request
• arrow_upward 22:46:04 Send join-request to cluster-local Join Server Selected MAC version MAC_V1_0_3
• arrow_upward 22:46:04 Receive join-request
I have triple checked DevEUI AppEUI and AppKEY. All are as required. Latest firmware on the 10701 with band set to AU915, the GW to Region AU915-928 and the TTN GW frequency plan to AU_915_928_FSB_2, au1 cluster.
I have reread the manual so many times but cannot see where I am going wrong.
The 10701 is set to 20s TX int, DR2, Tx Power 1. It tries 8 times at 20 s intervals with message ‘failed’ on the deivce each time then finally stalls showing message ‘joining’.
This is all new to me so appreciate any advice!
