RAK 12002 RTC conflict with ADS1115 connected to RAK 13009
  • What product do you wish to discuss? RAK4631, RAK3372, RAK11200, RAK11310, RAK11722? RAK 4631
  • What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)? Arduino BSP
  • What firmware version? Can it be obtained with AT+VER=?
  • Computer OS? (MacOS, Linux, Windows) Windows
  • What Computer OPreformatted textS version? Windows 11
  • How often does the problem happen? With every node I’ve tried
  • How can we replicate the problem? My setup is the RAK 19001, RAK 4631, RAK12002, RAK 13009, RAK 15002. I have an Adafruit ADS1115 connected via QWIIC to the RAK 13009. Every time I upload, the ADS is no longer powered. It seems to be a conflict with the RTC. It stays powered on until I upload the unix time to the RTC. After that I can’t get the ADS to power back on. When I use a RAK 1920 this isn’t an issue.
  • Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
main.ino
#include "config.h"
#include "storage.h"
#include "sensors.h"
#include "lora.h"
#include <Arduino.h>
#include "Melopero_RV3028.h"
#include "battery.h"
//#include <Wire.h>
Melopero_RV3028 rtc;
uint32_t lastSendSlot = 0;
#ifndef LED_BUILTIN
#define LED_BUILTIN 35  // green LED
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36  // blue LED
#endif
static uint32_t count = 0;
void setup() {
  pinMode(WB_IO2, OUTPUT);
  digitalWrite(WB_IO2, HIGH);   // Enable 3V3_S sensor rail
  delay(100);
  initBattery();
  initSensors();
  initSD();
  lora_init();
  joinLoRa();  // Start Join procedure
  // RTC setup
  rtc.initI2C();
  delay(100);
  rtc.writeToRegister(0x35, 0x00);
  rtc.writeToRegister(0x37, 0xB4);  //Direct Switching Mode (DSM): when VDD < VBACKUP, switchover occurs from VDD to VBACKUP
  Set unix time once or if the time needs reset then comment out
  after it is set on all other uploads!
  //rtc.setUnixTime( 1778528440 );
  // LED setup
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(LED_BUILTIN2, OUTPUT);
  digitalWrite(LED_BUILTIN2, LOW);
  time_t timeout = millis();
  while (!Serial) {
    if ((millis() - timeout) < 5000) {
      delay(100);
    } else {
      break;
  Serial.println("Setup complete");
void loop() {
  uint32_t now = rtc.getUnixTime();
  uint32_t currentSlot = now / SEND_INTERVAL;
  uint16_t battery_mv = readBatteryMV();
  if (currentSlot != lastSendSlot) {
    Serial.print("Battery: ");
    Serial.print(battery_mv);
    Serial.println(" mV");
    readSensors();
    logToSD(now, pressure, battery_mv);
    if (isLoRaJoined()) {
      sendLoRaFrame(pressure, battery_mv);
    } else {
      Serial.println("Not joined yet, data logged locally only");
    lastSendSlot = currentSlot;
  delay(5000);
sensor.cpp
//#include <Wire.h>
#include <Adafruit_ADS1X15.h>
// Sensor objects
Adafruit_ADS1115 ads1115;
// Sensor state
int16_t pressure = 0;
bool adsPresent = false;
bool shtPresent = false;
// Init sensors
void initSensors()
    //Wire.begin();
    // -------- ADS1115 --------
    if (ads1115.begin())
        Serial.println("ADS1115 detected.");
        adsPresent = true;
        ads1115.setGain(GAIN_ONE);
    else
        Serial.println("ADS1115 not found.");
        adsPresent = false;
// Read sensors
void readSensors()
    // -------- Pressure sensor --------
        pressure = ads1115.readADC_SingleEnded(0);
        adsPresent = true;
        Serial.print("pressure: ");
        Serial.println(pressure);
    else
        pressure = 0xFFFF; // sentinel value
        adsPresent = false;
        Serial.println("ADS missing → LW invalid");
two times checking “if (ads1115.begin())” ??
Welcom to RAK forum @spartan0 ,
Can you please share on what slots the sensors are connected? I check check for possible pin conflicts and recommend slot combinations that will work.
I ended up swapping the RTC in slot B and QWIIC connector in slot A and it works now. Thanks Carl!
