Does the RAK 19006 module come with the wireless charging coil? If not, is there a spec for the coil required? I can’t find any info on the website.
Hello @GadgetBoy , welcome to the forum.
The RAK19006 comes with a charging coil. It works with standard charging pads.
=> RAK19006 Quick Start Guide | RAKwireless Documentation Center
Hi Bernd,
Thanks for the reply. Is there a mechanical drawing or 3D model available for the coil?
Hello Matthew,
I had the same problem, wanted a 3D model for it.
But we are buying in the coil and I so far I could not get it.
Still no 3D model, but now I got at least a datasheet. We will add it to our documentation. For now, here are at least the dimensions (cannot attach PDF here)
Thanks BeeGee. This helps a lot.
There is also a GPS antenna that comes with RAK4361. Is there a drawing or model for the GPS antenna?
Same problem. Maybe I can get it on Monday.
That would be great, thanks for all your help.
