RAK 19007, 4631 meshtastic starter kit - USB communication failure
  • What product do you wish to discuss? RAK4631
  • What firmware are you using? arduino / DFU flashed on MAC OS Arm
  • What firmware version? Can it be obtained with AT+VER=? No
  • Computer OS? Debian Linux
  • What Computer OS version? Debian 13 headless install
  • How often does the problem happen? I am unable to send and receive via the USB port - /dev/ttyACM0
  • How can we replicate the problem?
    I have tried meshtastic, meshtasticd. The device is recognised in lsusb and dmesg show correct attachment when plugging in or removing. The issue is that there is no communication from the board - it remains silent. If I request meshtastic --port /dev/ttyACM0 – info it just hangs and times out with no connection. I am using the USB cable from the kit and used this to reflash with dfu, I tried the erase and adding the firmware again.
Is there a known issue, what am I missing as I understand it should be straight forward.
Welcome to the forum @James3d
Did you try from a computer, instead of the Raspberry Pi?
Did you try to connect to the device with a terminal application and check if there is any output coming over the USB?
Yes, I am trying to run it from an industrial style N100 mini pc and I also tried from terminal on a macbook. I gave up on raspberry pi as its wifi connectivity was too unstable.
Does the RAk4631 show up on BLE on a mobile app?
What exact firmware did you install on the RAK4631? The correct version is firmware-rak4631-w.x.yy.zzzzzzz.uf2 where the w.x.yy… is the version number.
As a side note, meshtasticd is for Raspberry Pi and not for a RAK4631.
Its been working fine over BLE meshtastic app. I installed firmware-rak4631-2.7.15.567b8ea.uf2 and also ran the nrf_erase2.uf2 to try to ensure a clean install.
I assumed meshtasticd was for linux in general. I will probably pull data via python meshtastic via a crom job.
@beegee any updates as I can also not get it to respond to serial on MacOS. I have purchased a 3312 which is working on meshtasticCLI, while I can traceroute to the 4631 I cannot get telemetry (it shows in the Meshtastic Andoid App). I have tried to connect to MacOS to set it up using meshtastic CLI but again no serial response. Please help as I am struggling.
The best way to setup the RAK3312 is to use the Meshtastic Web Client. And you can use the same for the RAK4631.
In my experience nrf_erase2.uf2 is not fully erasing the settings. I suggest you use our WisBlock-HW-Tester to make sure you have a clean module and test the serial communication with it.
WisBlock-HW-Tester is not Meshtastic, it is a HW test application that checks basic functionality of the WisBlock Core modules like
  • Connection to the LoRa transceiver
  • Serial output over USB
  • Flash Read/Write
After you flashed the test firmware, connect a serial terminal application to the device with 115200 Baud 8N1. You can see the log output with the test results.
WB_HW_Test_RAK4631_H_V3.0.0.uf2 (610.5 KB)
Thanks, I have it working now after multiple tries with the erase file on 3312 and the tester file worked on the 4631. I did find that in the serial output the messages testing the leds appeared briefly on a restart after reflashing meshtastic firmware.
I have now been able to access both devices over serial and can request telemetry from the remote node using meshtasticCLI on Debian with the 3312 connected by USB.
I can now move foward with logging/displaying data and adding more nodes!
Thanks for your help.
