I see the power usage is 5 watts, but what is the OUTPUT power ?
Actually it is 12W peak. The output power is area dependent and is automatically adjusted when you assert your location.
Vladislav
so in the USA, that would translate to what output power, I realize it says up to 27 decibels, but what would actually be its output wattage?.. 1/4 watt…? 1 watt,?
Hei,
I think the max is 21dBm.
Vladislav
Ok, so once its up and running, where do I find the info on the output ? who has it , and where to find it ?
Thank you , Paul
Hei,
This is not something we have access at this point, it is set by the firmware and the Helium Server, so only they can give you details. It is not something we have visibility or control of.
You would have to go directly to Helium.
Vladislav
Thank you so much for your time, Paul
IF I were to try and contact the helium server, do you happen to know where I could do that ?
Thank you, Paul
Hei,
Contact the Helium Server to do what?
Your Hotspot is contacting it all the time …
Vladislav
