I’m building rugged LoRa nodes (car-mounted, solar-powered, off-grid) and recently switched to the RAK 3112 for its features. However, the MHF4 (IPEX4) connectors are a major pain point they pop off with the slightest tension, even with careful strain relief.
For context:
• All my current production nodes use the RAK19007 + RAK4631 combo with MHF1 connectors.
• I use RG178 coax (which works perfectly with MHF1 but is too thick for reliable MHF4 mating).
• These nodes survive vibration, weather, and rough handling but MHF4 fails instantly.
I found this 3D-printable MHF4 pigtail bracket on Printables and am testing it as a temporary fix:
We understand your feedback on MHF4 connector. It was a tradeoff we had to make to maintain the small form factor. MHF4 has lesser retention force compared to MHF1 due to mechanical limitations (it is just small).
Great work on the DIY bracket. Other option is to put adhesives to maintain it in place.
Also compared to MHF1, MHF4 are not generally designed for multiple removal. Once the antenna connector is plugged-in, it is recommended to keep the connection unless for necessary repairs or adjustment. This is something to keep in mind while doing prototyping.
Hot glue can help it stick in place but use it for strain relief and not directly on the connector. The glue can go in to the connector and can be more problematic specially if you want to disconnect the connector.
The MHF4 connector should still have enough locking force but since it is very tiny, it can be easily removed and repeated disconnect will make it worse.
A tape or 3d printed mount/clamp on top of it is a better option.
Btw, you have to check if the connector is still ok. If it doesn’t look good and have poor RF compared before, it might be a good idea to try to get it replaced.
