Is RAK 3172- T with Firmware Version 4.2.1 is LoRaWAN MAC Version 1.0.4 Please Confirm.
Please Specify The Joining Procedure with 1.0.4 and Things Network Server changes
There is no change on the device.
For TTN, please check TTN’s documentation. Usually it is just selecting the correct LoRaWAN version when registering the device.
can You Specify Which Regional Parameters has to be used for Firmware Version 4.2.1 for RAK 3172 using 1.0.4 Stack ?
Choose RP002-1.0.4 for the Regional Parameters
RAK 7268 is Compatible To accept 1.0.4 Data BY default or need to update Firmware of Gateway too ?
No need to update the gateway.
Can you elaborate what setting should i do on things network and in RAK 3172-T to Join faithfully with class C and US915 FSB 1 Setting
also provide bin file for RAK 3172 -T 4.0.6 Firmware Version
You can find all files in our Download Center
Latest version is RUI3 V4.2.1
Older versions can be found in the folder History-Release-Version/
