Is there a way to force spreading force used during join ?
I would like to force joining using SF12 (in order to get a shorter join process) and let ADR does its job
Of course I’m using GitHub - beegee-tokyo/SX126x-Arduino: Arduino library to use Semtech SX126x LoRa chips and modules to communicate
Welcome back @Batto
In LoRaWAN protocol the allowed DR’s (BW + SF) for join are fixed by the regional parameters. What region are you using? If SF12 is allowed, it might need a patch in the library code, there is no command to set it through API call.
EU868 Ok I will try to code code it Thanks !
