deFRAGer
(James Smith)
May 29, 2024, 8:58pm
1
I’m designing a circuit for a RAK 4630.
From reading other posts, it appears to optimally power the module it is best to supply +3.3VDC and +3.6VDC.
I’m wondering if anyone would know the max power consumption of the rails (full transmit, Bluetooth and LoRa, and processing on the nRF52), so I can pick appropriately sized inductors for max efficiency.
crmrosa
(claudio roberto machado da rosa)
May 30, 2024, 12:37am
2
Take a look in the one of base boards documentation: RAK19007
Regards,
Cláudio
deFRAGer
(James Smith)
May 30, 2024, 12:46am
3
This isn’t what I’m after sadly; I’m well versed in the core setup.
beegee
(Bernd Giesecke)
May 30, 2024, 5:09am
4
There is no definite value for the max current.
It depends on too many factors, like
BLE TX power
LoRa TX power
LoRaWAN region
LoRa packet size
LoRaWAN data rate
other modules attached to the system
and mostly about your application being low power optimized or running useless in the loop() waiting for something to happen
deFRAGer
(James Smith)
May 30, 2024, 5:13am
5
That’s fair. Do you know if it’s an equal split across 3.3v and 3.6v? The 3.3v would be for the SX1262 and the 3.6v is for the nRF?
beegee
(Bernd Giesecke)
May 30, 2024, 5:33am
6
It depends how you connect the different supply pins.
On the WisBlock RAK4631 it is like shown in the schematics
The SX1262 is supplied by 3.3V and the nRF52 is supplied by 3.6V-4.2V from the battery
deFRAGer
(James Smith)
May 30, 2024, 6:40am
7
I’ll be setting it up like this.
beegee
(Bernd Giesecke)
May 30, 2024, 6:45am
8
That should be ok. If you have space, I would add some surge protection on the USB+/USB- lines
