What product do you wish to discuss? RAK4631
What firmware are you using? NRF Connect SDK + Zephyr OS
What firmware version? RUI3 Bootloader has been flashed via Jlink
Computer OS? Windows 11
I am have been having an issue with the reset pin on the RAK4631 board. The board seems to get suck in a reset loop after powering on, until I manually tap 3.3v onto the reset pin with jumper. After tapping the pin it becomes “unstuck” and functions normally.
The reset pin is sitting at 2.2v when idle. I am wondering if that may not be high enough to be a logic high? I have tested the 10k resistor and 100nf cap and both are fine.
I am not sure if it is a faulty board/hardware, or if there is an issue with the firmware. Any advice would be appreciated.
Thanks.
If you flash a “normal” WisBlock Bootloader & application, is it the same?
If it works normally, it might be a wrong setup in your Zephyr setup. But I can’t help with that.
You can have a look into our Amazon Sidewalk firmware example. That uses Zephyr and run’s fine on a RAK4631 WisBlock.
The issue has resolved after flashing a hexdump that you provided in the thread “Upgrade to RUI3 failing on RAK4630” - RAK4631-RUI3-V4.1.1-Flash-Dump.hex
I am now able to flash my Zephyr application and reset the board without issue, so I must have had the wrong bootloader version?
I usually use the “RAK4631-RUI3-V4.1.1-Flash-Dump.hex” you found in the other thread and flash it with JLink when switching between RUI3 and Arduino. That file includes bootloader, softdevice and application code.
Not sure if the bootloader required for Zephyr is the same or different.
