RAK 5010 does not connect to cellular network
I have connected RAK 5010 with usb port and using Termite software to read the At commands response. I am getting this response and have tried with hologram, airtel and Jio sim cards but same response. It could not connect to cellular network. This is as described here:
https://doc.rakwireless.com/rak5010-wistrio-nb-iot-tracker/connecting-cellular-network-and-sending-packet-over-cellular
Did i miss any command.
RDY means the volgate is not stable, 5010 need at least 3.3V. So please keep the usb volgate stable or connect a chargeable battery.
If you use hologram, just send as below:
at+set_config=cellular:(AT+COPS=?) //search net
at+set_config=cellular:(AT+COPS?) //query your net
at+set_config=cellular:(AT+COPS=1,0,“hologram”,0) //set apn
at+set_config=cellular:(AT+QIACT=1) //active
Hologram will self-adaption the net.
Thanks @nero, it helps . i thought RDY means modem is Ready . Powered it with battery , it does not show RDY message on terminal. and it does connect finally, there is one change though
at+set_config=cellular:(AT+CGDCONT=1,“IP”,“hologram”)
and it works. Thanks
