This is the at+version. output OK3.1.0.13
What was the previous version?
I think 3.0.0.11 or 12, sorry I don’t remember very well.
I recommend that you erase the entire board, as the previous version may be the main cause of the problem.
The normal version will have 30S configuration time before the join, but does this information not appear in your screenshot?
I followed this thread Error while joining RAK 5205 OTAA failed
I switched to AU915 and after to EU868, this is the output of at+get_config=lora:channel
OK *0,on,868100000,0,5; *1,on,868300000,0,5; *2,on,868500000,0,5; 3,off,0,0,0; 4,off,0,0,0; 5,off,0,0,0; 6,off,0,0,0; 7,off,0,0,0; *8,on,867100000,0,5; *9,on,867300000,0,5; *10,on,867500000,0,5; *11,on,867700000,0,5; *12,on,867900000,0,5; 13,off,0,0,0; 14,off,0,0,0; 15,off,0,0,0
However It seems that cannot join the network
PS: I reflashed all again, but same result
Are there any other errors now?
OTAA Join Start…
AT format error.
[LoRa]:Join retry Cnt:1
[LoRa]:Join retry Cnt:2
[LoRa]:Join retry Cnt:3
[LoRa]:Join retry Cnt:4
[LoRa]:Join retry Cnt:5
[LoRa]:Joined Failed!
OK Sleep
Do you have other nodes to connect to the gateway? The same parameters are configured with RAK7200.
Yes, RAK 7204, connected without problem
| ___ / _ \ | | / / | | | () | |
| |/ / /\ | |/ / | | | | _ __ | | ___ ___ ___
| /| _ || \ | |/| | | '/ _ \ |/ _ / __/ __|
| |\ | | | || |\ \ \ /\ / | | | __/ | /_ _
_| __| |/_| _/ / /||| _|_|_||//
RAK7200 version:3.1.0.13
Please Configurate parameters within 30 seconds …
lorasend_interval: 300s
MPU9250 Init OK
GPS Init OK
Initialization OK,Current work_mode:LoRaWAN, join_mode:OTAA, Class: A
gps_timeout: 100s
Configuration OK!
OTAA Join Start…
OK Sleep
So now the question is whether the gateway communicates with the node, can any data be seen on the server during the join?
MPU9250 Init OK
GPS Init OK
gps_timeout: 100s
Configuration OK!
OTAA Join Start…
OK Sleep
Wake up .
GPS Init OK
OTAA Join Start…
OK Sleep
Wake up .
GPS Init OK
OTAA Join Start…
OK Sleep
Wake up .
GPS Init OK
OTAA Join Start…
OK Sleep
Wake up .
GPS Init OK
OTAA Join Start…
OK Sleep
This is the server log:
“downlinkMetaData”: {
“txInfo”: {
“gatewayID”: “MjQzNlkAPQA=”,
“frequency”: 868500000,
“power”: 14,
“modulation”: “LORA”,
“loRaModulationInfo”: {
“bandwidth”: 125,
“spreadingFactor”: 12,
“codeRate”: “4/5”,
“polarizationInversion”: true
“board”: 0,
“antenna”: 0,
“timing”: “DELAY”,
“delayTimingInfo”: {
“delay”: “5s”
“context”: “24p3nQ==”
“phyPayload”: {
“mhdr”: {
“mType”: “JoinAccept”,
“major”: “LoRaWANR1”
“macPayload”: {
“bytes”: “r+Hett188+C/9picg7y0vU1GLfsH+/MWZvju1w==”
“mic”: “ff0a9ac6”
“uplinkMetaData”: {
“rxInfo”: [
“time”: null,
“timeSinceGPSEpoch”: null,
“rssi”: -108,
“loRaSNR”: 4.5,
“channel”: 2,
“rfChain”: 1,
“board”: 0,
“antenna”: 0,
“location”: {
“latitude”: 0,
“longitude”: 0,
“altitude”: 0,
“source”: “UNKNOWN”,
“accuracy”: 0
“fineTimestampType”: “NONE”,
“context”: “24p3nQ==”,
“uplinkID”: “RRJF9qFMT/WRu64962Rtfg==”,
“crcStatus”: “CRC_OK”
“txInfo”: {
“bandwidth”: 125,
“codeRate”: “4/5”,
“polarizationInversion”: false
“phyPayload”: {
“mhdr”: {
“mType”: “JoinRequest”,
“macPayload”: {
“joinEUI”: “7083d57ed001c1cf”,
“devEUI”: “60c5a8fffe761c1d”,
“devNonce”: 19495
“mic”: “f6eceba9”
“txInfo”: {
“frequency”: 868300000,
“power”: 14,
“bandwidth”: 125,
“spreadingFactor”: 11,
“codeRate”: “4/5”,
“board”: 0,
“antenna”: 0,
“timing”: “DELAY”,
“delay”: “5s”
“context”: “2wWkYA==”
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“bytes”: “k6zGGTiHhnven4TTz6TldiVSbr68xBv4bmJZbQ==”
“mic”: “935d6bb8”
“uplinkMetaData”: {
“rxInfo”: [
“time”: null,
“rssi”: -104,
“loRaSNR”: 5.75,
“channel”: 1,
“rfChain”: 1,
“board”: 0,
“antenna”: 0,
“location”: {
“latitude”: 0,
“longitude”: 0,
“altitude”: 0,
“accuracy”: 0
“context”: “2wWkYA==”,
“uplinkID”: “Z4cfVZW3S0OVsWq4tPlU4g==”,
“txInfo”: {
“bandwidth”: 125,
“codeRate”: “4/5”,
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“devNonce”: 44794
“mic”: “53a615a9”
“txInfo”: {
“power”: 14,
“bandwidth”: 125,
“spreadingFactor”: 10,
“codeRate”: “4/5”,
“board”: 0,
“antenna”: 0,
“timing”: “DELAY”,
“delay”: “5s”
“context”: “2pM8rw==”
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“bytes”: “oF5FtnCDd1FVta/5LaA5mLftPATZun680AVsvw==”
“mic”: “cd4bfa28”
“uplinkMetaData”: {
“rxInfo”: [
“time”: null,
“rssi”: -107,
“loRaSNR”: 5.75,
“channel”: 1,
“rfChain”: 1,
“board”: 0,
“antenna”: 0,
“location”: {
“latitude”: 0,
“longitude”: 0,
“altitude”: 0,
“accuracy”: 0
“context”: “2pM8rw==”,
“uplinkID”: “wjlmVU9XTE+R1wPO5p79qg==”,
“txInfo”: {
“bandwidth”: 125,
“codeRate”: “4/5”,
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“devNonce”: 37214
“mic”: “1f2e5e43”
“txInfo”: {
“power”: 14,
“bandwidth”: 125,
“spreadingFactor”: 9,
“codeRate”: “4/5”,
“board”: 0,
“antenna”: 0,
“timing”: “DELAY”,
“delay”: “5s”
“context”: “2iU78w==”
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“bytes”: “hwzysuXeCxpZeAD0/bITuA9xKf9enj3uyrf0yA==”
“mic”: “c4b1c57c”
“uplinkMetaData”: {
“rxInfo”: [
“time”: null,
“rssi”: -106,
“loRaSNR”: 5.5,
“channel”: 2,
“rfChain”: 1,
“board”: 0,
“antenna”: 0,
“location”: {
“latitude”: 0,
“longitude”: 0,
“altitude”: 0,
“accuracy”: 0
“context”: “2iU78w==”,
“uplinkID”: “/hHNPlBKSxaElMCxv7PffQ==”,
“txInfo”: {
“bandwidth”: 125,
“codeRate”: “4/5”,
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“devNonce”: 48599
“mic”: “433df458”
“txInfo”: {
“power”: 14,
“bandwidth”: 125,
“spreadingFactor”: 8,
“codeRate”: “4/5”,
“board”: 0,
“antenna”: 0,
“timing”: “DELAY”,
“delay”: “5s”
“context”: “2bhICA==”
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“bytes”: “fOB901yPZ2DiMFkY6eFRKbCqGMjgXyF67aw27w==”
“mic”: “3a35efa7”
“uplinkMetaData”: {
“rxInfo”: [
“time”: null,
“rssi”: -108,
“loRaSNR”: 6.5,
“channel”: 1,
“rfChain”: 1,
“board”: 0,
“antenna”: 0,
“location”: {
“latitude”: 0,
“longitude”: 0,
“altitude”: 0,
“accuracy”: 0
“context”: “2bhICA==”,
“uplinkID”: “aeBYsM99Tz2sRs2B9mL4Qw==”,
“txInfo”: {
“bandwidth”: 125,
“codeRate”: “4/5”,
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“devNonce”: 51877
“mic”: “2c8b120d”
“txInfo”: {
“frequency”: 868100000,
“power”: 14,
“bandwidth”: 125,
“spreadingFactor”: 7,
“codeRate”: “4/5”,
“board”: 0,
“antenna”: 0,
“timing”: “DELAY”,
“delay”: “5s”
“context”: “2UvxHg==”
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“bytes”: “0evIWUWxI+44KGKnn68MZXD5OHN8aKT5Gqt9Qg==”
“mic”: “1870553e”
“uplinkMetaData”: {
“rxInfo”: [
“time”: null,
“rssi”: -106,
“loRaSNR”: 5.5,
“channel”: 0,
“rfChain”: 1,
“board”: 0,
“antenna”: 0,
“location”: {
“latitude”: 0,
“longitude”: 0,
“altitude”: 0,
“accuracy”: 0
“context”: “2UvxHg==”,
“uplinkID”: “wdycWf5BQkei0vHV79QgFA==”,
“txInfo”: {
“bandwidth”: 125,
“codeRate”: “4/5”,
“phyPayload”: {
“mhdr”: {
“macPayload”: {
“devNonce”: 50295
“mic”: “38ae1eb3”
Gateway and node of the antenna is not removed! From the log found that the rssi is very bad!
Many thanks for your support, I resolved the issue!
Could you tell me what caused it?
The error 91 was related to the blank channel list, switched from EU868 to AU915 and back again. After this, all the channel table was correctly populated.
The last problem was related to the signal, I moved the RAK7200 in other postion and it joined the network, however, all my previous test had been made in that position.
Okay,thank you!
