Here is some log info…
Fri Jun 7 14:32:11 2024 kern.info quectel-CM[2051]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:32:13 2024 kern.info quectel-CM[2051]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:32:15 2024 user.notice data-broker: data-broker timeout, restart it
Fri Jun 7 14:32:15 2024 kern.info quectel-CM[2051]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:32:17 2024 kern.info quectel-CM[2051]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:32:19 2024 kern.info quectel-CM[2051]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1524.990000] usb 1-1.1: USB disconnect, device number 39
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1525.000000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1525.010000] option 1-1.1:1.0: device disconnected
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1525.020000] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1525.040000] option 1-1.1:1.1: device disconnected
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1525.050000] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1525.070000] option 1-1.1:1.2: device disconnected
Fri Jun 7 14:32:20 2024 kern.err kernel: [ 1525.080000] option1 ttyUSB5: usb_wwan_indat_callback: resubmit read urb failed. (-19)
Fri Jun 7 14:32:20 2024 kern.err kernel: [ 1525.090000] qmi_wwan 1-1.1:1.4: Tx URB error: -19
Fri Jun 7 14:32:20 2024 kern.err kernel: [ 1525.110000] option1 ttyUSB5: usb_wwan_indat_callback: resubmit read urb failed. (-19)
Fri Jun 7 14:32:20 2024 kern.err kernel: [ 1525.120000] option1 ttyUSB5: usb_wwan_indat_callback: resubmit read urb failed. (-19)
Fri Jun 7 14:32:20 2024 kern.err kernel: [ 1525.140000] option1 ttyUSB5: usb_wwan_indat_callback: resubmit read urb failed. (-19)
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1525.160000] option1 ttyUSB5: GSM modem (1-port) converter now disconnected from ttyUSB5
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1525.170000] option 1-1.1:1.3: device disconnected
Fri Jun 7 14:32:20 2024 kern.info kernel: [ 1525.190000] qmi_wwan 1-1.1:1.4 wwan0: unregister ‘qmi_wwan’ usb-101c0000.ehci-1.1, WWAN/QMI device
Fri Jun 7 14:32:20 2024 daemon.notice netifd: Network device ‘wwan0’ link is down
Fri Jun 7 14:32:20 2024 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Fri Jun 7 14:32:20 2024 daemon.notice netifd: Interface ‘wwan6’ has link connectivity loss
Fri Jun 7 14:32:20 2024 daemon.notice netifd: wwan (2346): Read error: Network is down, reopening socket
Fri Jun 7 14:32:20 2024 kern.info quectel-CM[2051]: QmiWwanSendQMI write=-1, errno: 19 (No such device)
Fri Jun 7 14:32:20 2024 kern.info quectel-CM[2051]: QmiWwanThread poll err/hup/inval
Fri Jun 7 14:32:20 2024 kern.info quectel-CM[2051]: poll fd = 7, events = 0x0018
Fri Jun 7 14:32:20 2024 kern.info quectel-CM[2051]: QmiWwanThread exit
Fri Jun 7 14:32:21 2024 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Fri Jun 7 14:32:21 2024 daemon.notice netifd: Interface ‘wwan’ is disabled
Fri Jun 7 14:32:21 2024 daemon.notice netifd: Interface ‘wwan6’ is disabled
Fri Jun 7 14:32:21 2024 daemon.notice netifd: wwan (2346): udhcpc: bind: No such device
Fri Jun 7 14:32:21 2024 kern.info quectel-CM[2051]: QmiWwanSendQMI cdc_wdm_fd = -1
Fri Jun 7 14:32:22 2024 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Fri Jun 7 14:32:22 2024 kern.info quectel-CM[2051]: QmiWwanSendQMI cdc_wdm_fd = -1
Fri Jun 7 14:32:23 2024 kern.info quectel-CM[2051]: QmiWwanSendQMI cdc_wdm_fd = -1
Fri Jun 7 14:32:24 2024 kern.info quectel-CM[2051]: main Failed to QmiWwanInit: 19 (No such device)
Fri Jun 7 14:32:26 2024 kern.info quectel-CM[3036]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Fri Jun 7 14:32:26 2024 kern.info quectel-CM[3036]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Fri Jun 7 14:32:26 2024 user.notice root: echo 1 > /sys/class/gpio/gpio2/value
Fri Jun 7 14:32:27 2024 user.notice root: echo 0 > /sys/class/gpio/gpio2/value
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: ##### 2024-06-07 04:32:40 UTC #####
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: ### [UPSTREAM] ###
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # RF packets received by concentrator: 1
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # CRC_OK: 100.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # RF packets forwarded: 1 (16 bytes)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # PUSH_DATA datagrams sent: 2 (333 bytes)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # PUSH_DATA acknowledged: 100.00
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: ### [DOWNSTREAM] ###
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # PULL_DATA sent: 6 (100.00 acknowledged)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # RF packets sent to concentrator: 0 (0 bytes)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # TX errors: 0
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # TX rejected (collision packet): 0.00 (req:6, rej:0)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # TX rejected (collision beacon): 0.00 (req:6, rej:0)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # TX rejected (too late): 0.00 (req:6, rej:0)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # TX rejected (too early): 0.00 (req:6, rej:0)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # BEACON queued: 0
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # BEACON sent so far: 0
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # BEACON rejected: 0
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: ### [JIT] ###
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # SX1301/SX1302 time (PPS): 1484070228, offset us 0
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: ### [GPS] ###
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # Invalid time reference (age: 1717734760 sec)
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: # no valid GPS coordinates available yet
Fri Jun 7 14:32:40 2024 user.notice lora_pkt_fwd[2817]: ##### END #####
Fri Jun 7 14:32:40 2024 kern.info kernel: [ 1544.940000] usb 1-1.1: new high-speed USB device number 40 using ehci-platform
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.070000] usb 1-1.1: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.070000] option 1-1.1:1.0: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.070000] option 1-1.1:1.0: GSM modem (1-port) converter detected
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.080000] option1 ttyUSB2: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.080000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.100000] option 1-1.1:1.1: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.100000] option 1-1.1:1.1: GSM modem (1-port) converter detected
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.110000] option1 ttyUSB3: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.110000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.120000] option 1-1.1:1.2: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.120000] option 1-1.1:1.2: GSM modem (1-port) converter detected
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.140000] option1 ttyUSB4: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.140000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB4
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.150000] option 1-1.1:1.3: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.150000] option 1-1.1:1.3: GSM modem (1-port) converter detected
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.160000] option1 ttyUSB5: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.160000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB5
Fri Jun 7 14:32:41 2024 kern.debug kernel: [ 1545.180000] qmi_wwan 1-1.1:1.4: no of_node; not parsing pinctrl DT
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.190000] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.200000] qmi_wwan 1-1.1:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Fri Jun 7 14:32:41 2024 kern.info kernel: [ 1545.220000] qmi_wwan 1-1.1:1.4 wwan0: register ‘qmi_wwan’ at usb-101c0000.ehci-1.1, WWAN/QMI device, 02:72:9c:75:0a:63
Fri Jun 7 14:32:41 2024 daemon.notice netifd: Interface ‘wwan’ is enabled
Fri Jun 7 14:32:41 2024 daemon.notice netifd: Interface ‘wwan6’ is enabled
Fri Jun 7 14:32:41 2024 daemon.notice netifd: Network device ‘wwan0’ link is up
Fri Jun 7 14:32:41 2024 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Fri Jun 7 14:32:41 2024 daemon.notice netifd: Interface ‘wwan’ is setting up now
Fri Jun 7 14:32:41 2024 daemon.notice netifd: Interface ‘wwan6’ has link connectivity
Fri Jun 7 14:32:41 2024 daemon.notice netifd: Interface ‘wwan6’ is setting up now
Fri Jun 7 14:32:41 2024 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Fri Jun 7 14:32:41 2024 daemon.notice netifd: wwan (3327): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Fri Jun 7 14:32:41 2024 daemon.notice netifd: wwan (3327): udhcpc (v1.23.2) started
Fri Jun 7 14:32:41 2024 daemon.notice netifd: wwan (3327): Sending discover…
Fri Jun 7 14:32:41 2024 user.notice hotplug: Symlink from /dev/ttyUSB4 to /dev/ttyATWWAN created
Fri Jun 7 14:32:44 2024 daemon.notice netifd: wwan (3327): Sending discover…
Fri Jun 7 14:32:47 2024 daemon.notice netifd: wwan (3327): Sending discover…
Fri Jun 7 14:32:52 2024 kern.info quectel-CM[3036]: Find /sys/bus/usb/devices/1-1.1 idVendor=2c7c idProduct=0195
Fri Jun 7 14:32:52 2024 kern.info quectel-CM[3036]: Find /sys/bus/usb/devices/1-1.1:1.4/net/wwan0
Fri Jun 7 14:32:52 2024 kern.info quectel-CM[3036]: Find usbnet_adapter = wwan0
Fri Jun 7 14:32:52 2024 kern.info quectel-CM[3036]: Find /sys/bus/usb/devices/1-1.1:1.4/usbmisc/cdc-wdm0
Fri Jun 7 14:32:52 2024 kern.info quectel-CM[3036]: Find qmichannel = /dev/cdc-wdm0
Fri Jun 7 14:32:52 2024 kern.info quectel-CM[3036]: cdc_wdm_fd = 7
Fri Jun 7 14:32:53 2024 kern.info quectel-CM[3036]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:32:55 2024 kern.info quectel-CM[3036]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:32:57 2024 kern.info quectel-CM[3036]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:32:59 2024 kern.info quectel-CM[3036]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:33:01 2024 kern.info quectel-CM[3036]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:33:03 2024 kern.info quectel-CM[3036]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.510000] usb 1-1.1: USB disconnect, device number 40
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.520000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.540000] option 1-1.1:1.0: device disconnected
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.540000] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.560000] option 1-1.1:1.1: device disconnected
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.570000] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.590000] option 1-1.1:1.2: device disconnected
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.600000] option1 ttyUSB5: GSM modem (1-port) converter now disconnected from ttyUSB5
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.610000] option 1-1.1:1.3: device disconnected
Fri Jun 7 14:33:04 2024 daemon.notice netifd: Network device ‘wwan0’ link is down
Fri Jun 7 14:33:04 2024 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Fri Jun 7 14:33:04 2024 daemon.notice netifd: Interface ‘wwan6’ has link connectivity loss
Fri Jun 7 14:33:04 2024 daemon.notice netifd: wwan (3327): Read error: Network is down, reopening socket
Fri Jun 7 14:33:04 2024 kern.info kernel: [ 1568.640000] qmi_wwan 1-1.1:1.4 wwan0: unregister ‘qmi_wwan’ usb-101c0000.ehci-1.1, WWAN/QMI device
Fri Jun 7 14:33:04 2024 kern.info quectel-CM[3036]: QmiWwanThread poll err/hup/inval
Fri Jun 7 14:33:04 2024 kern.info quectel-CM[3036]: poll fd = 7, events = 0x0018
Fri Jun 7 14:33:04 2024 kern.info quectel-CM[3036]: QmiWwanThread exit
Fri Jun 7 14:33:04 2024 kern.info quectel-CM[3036]: QmiWwanSendQMI cdc_wdm_fd = -1
Fri Jun 7 14:33:04 2024 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Fri Jun 7 14:33:04 2024 daemon.notice netifd: Interface ‘wwan’ is disabled
Fri Jun 7 14:33:04 2024 daemon.notice netifd: Interface ‘wwan6’ is disabled
Fri Jun 7 14:33:04 2024 daemon.notice netifd: wwan (3327): udhcpc: bind: No such device
Fri Jun 7 14:33:05 2024 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Fri Jun 7 14:33:05 2024 kern.info quectel-CM[3036]: QmiWwanSendQMI cdc_wdm_fd = -1
Fri Jun 7 14:33:06 2024 kern.info quectel-CM[3036]: QmiWwanSendQMI cdc_wdm_fd = -1
Fri Jun 7 14:33:07 2024 kern.info quectel-CM[3036]: QmiWwanSendQMI cdc_wdm_fd = -1
Fri Jun 7 14:33:08 2024 kern.info quectel-CM[3036]: main Failed to QmiWwanInit: 2 (No such file or directory)
Fri Jun 7 14:33:10 2024 kern.info quectel-CM[3954]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Fri Jun 7 14:33:10 2024 kern.info quectel-CM[3954]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Fri Jun 7 14:33:10 2024 user.notice root: echo 1 > /sys/class/gpio/gpio2/value
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: ##### 2024-06-07 04:33:10 UTC #####
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: ### [UPSTREAM] ###
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # RF packets received by concentrator: 0
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # RF packets forwarded: 0 (0 bytes)
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # PUSH_DATA datagrams sent: 1 (135 bytes)
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # PUSH_DATA acknowledged: 100.00
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: ### [DOWNSTREAM] ###
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # PULL_DATA sent: 6 (100.00 acknowledged)
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # RF packets sent to concentrator: 0 (0 bytes)
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # BEACON sent so far: 0
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # BEACON rejected: 0
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: ### [JIT] ###
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # SX1301/SX1302 time (PPS): 1514071046, offset us 0
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: ### [GPS] ###
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # Invalid time reference (age: 1717734790 sec)
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: # no valid GPS coordinates available yet
Fri Jun 7 14:33:10 2024 user.notice lora_pkt_fwd[2817]: ##### END #####
Fri Jun 7 14:33:11 2024 user.notice root: echo 0 > /sys/class/gpio/gpio2/value
Fri Jun 7 14:33:23 2024 kern.info kernel: [ 1588.200000] usb 1-1.1: new high-speed USB device number 41 using ehci-platform
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.330000] usb 1-1.1: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.330000] option 1-1.1:1.0: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.330000] option 1-1.1:1.0: GSM modem (1-port) converter detected
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.340000] option1 ttyUSB2: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.340000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.360000] option 1-1.1:1.1: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.360000] option 1-1.1:1.1: GSM modem (1-port) converter detected
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.370000] option1 ttyUSB3: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.370000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.380000] option 1-1.1:1.2: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.380000] option 1-1.1:1.2: GSM modem (1-port) converter detected
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.400000] option1 ttyUSB4: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.400000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB4
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.410000] option 1-1.1:1.3: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.410000] option 1-1.1:1.3: GSM modem (1-port) converter detected
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.420000] option1 ttyUSB5: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.420000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB5
Fri Jun 7 14:33:24 2024 kern.debug kernel: [ 1588.440000] qmi_wwan 1-1.1:1.4: no of_node; not parsing pinctrl DT
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.450000] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.460000] qmi_wwan 1-1.1:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Fri Jun 7 14:33:24 2024 kern.info kernel: [ 1588.480000] qmi_wwan 1-1.1:1.4 wwan0: register ‘qmi_wwan’ at usb-101c0000.ehci-1.1, WWAN/QMI device, 02:72:9c:75:0a:63
Fri Jun 7 14:33:24 2024 daemon.notice netifd: Interface ‘wwan’ is enabled
Fri Jun 7 14:33:24 2024 daemon.notice netifd: Interface ‘wwan6’ is enabled
Fri Jun 7 14:33:24 2024 daemon.notice netifd: Network device ‘wwan0’ link is up
Fri Jun 7 14:33:24 2024 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Fri Jun 7 14:33:24 2024 daemon.notice netifd: Interface ‘wwan’ is setting up now
Fri Jun 7 14:33:24 2024 daemon.notice netifd: Interface ‘wwan6’ has link connectivity
Fri Jun 7 14:33:24 2024 daemon.notice netifd: Interface ‘wwan6’ is setting up now
Fri Jun 7 14:33:24 2024 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Fri Jun 7 14:33:24 2024 daemon.notice netifd: wwan (4235): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Fri Jun 7 14:33:24 2024 daemon.notice netifd: wwan (4235): udhcpc (v1.23.2) started
Fri Jun 7 14:33:24 2024 daemon.notice netifd: wwan (4235): Sending discover…
Fri Jun 7 14:33:24 2024 user.notice hotplug: Symlink from /dev/ttyUSB4 to /dev/ttyATWWAN created
Fri Jun 7 14:33:25 2024 user.notice hotplug: Cannot find LORA usb proper mapping, exit
