RAK 7249 multiple networks as target
I want to relay data not only for TTN but also for other (in my case private) networks.
On the GUI I can only enter one network as a target.
I found one could enter a target in the global_conf.json file.
But that does not seem to work either.
Has someone an Idea?
I can provide more data if you tell me which.
Part of my /usr/share/lora/global_conf.json
“gateway_conf”: {
“server_address”: “router.eu.thethings.network”,
“serv_port_up”: 1700,
“serv_port_down”: 1700,
“servers”: [ {
“serv_enabled”: true
“server_address”: “private-server.tld”,
“serv_port_up”: 1680,
“serv_port_down”: 1680,
Hello @myfairlady
RAK7249 does not support poly packet forwarding. If you want to use it this way you have to bridge it with “server” where you run poly packet forwarder.
Todor Velev
Hello @velev
Thank you for your answer.
Is it correct that you have no outdoor Gateway that is polypaket capable then?
I also would also like this feature.
We’re a local government organisation looking at deploying a number of gateways within our boundaries for internal use, i…e forwarding to our own application servers etc, however we’d also like to offer the gateways for public use with TTN.
I would like to know also
