Received my RAK 7258 and reviewed docs but sure could use a tutorial and sample application. I want to use the built in lora server,mqtt, and thingspeak. Most tutorials use ttn but I am using 433 mhz. Thanks.
Hi @deltadesigntech,
Can you be a little more specific, what do you envision as an useful tutorial?
Sample application of what doing what ?
There is already a document explaining how to configure the built-in LoRa Server and the MQTT Bridge.
Thingspeak might be a good idea to investigate, I agree.
What does using 433MHz have to do with anything, it is not related to the rest of the configuration.
Vladislav
Hi,thanks for the quick response,
I am a newby to lora. Here is a sample tutorial.
https://os.mbed.com/docs/mbed-os/v5.13/tutorials/LoRa-tutorial.html
As i understand it, 433 is not compatible with ttn. I think I would rather set up a local server anyway, just trying to gather as much knowledge as possible before diving in.
There is a built in server in the RAKwireless Gateway products
For instructions refer to the doc:
Industrial Gateways:
We are working on a guide for connecting to a separately hosted LoRaServer, it should be done by the end of the week.
Regars
Vladislav
Great, thankyou
Rob Fisher
Hi…has anyone tried to place this gateway inside the IP67 box that RAK also sells? I just bought the two devices together with an antenna for 915 MHz frequency and I have decided to place the card of this gateway inside the outdoor box and place the external antenna of 5.8 dBi for greater range.
