RAK 7268-N won't start
Hello everyone,
I have the aforementioned gateway, but for some time now it has not started or booted correctly.
The green PWR LED lights up permanently.
Other LEDs do not light up. I connected the gateway via the Ethernet port.
But no LEDs next to the network plug light up.
I first pressed the reset button briefly, then pressed it for 5 seconds and finally pressed it for over 10 seconds. - Unfortunately, each time without any effect.
The device has a TF card. - Can I use this to install new firmware or something similar if there is a problem?
I would be grateful for any help! - Many thanks and best regards - Daniel
Hello, I would like to ask again about the above issue to see if someone can help me. Could it be that there is a problem with the firmware? Is it possible to find out what the problem is with the device via the “Console” interface? What can I do to read out log data or an error report, for example? Unfortunately, I am fairly inexperienced in these things and would appreciate some help. - Many thanks and best regards - Daniel
Better send the problem to [email protected].
Hello, I had some hard lessons to learn, but I was finally able to help myself and fix the issue: :wink:
  1. My gateway apparently had a problem with the last firmware I did install by update Update.
  2. You can access the gateway via the console interface. Using console software (CoolTerm) I was able to get into the boot menu. (Note: You have to set the Baudrate to 9600. Otherwise you will only see chinese an greek letters)
  3. In the boot menu it was finally possible to establish a connection to a TFTP-server using option two. I had no idea what that was until now, but with an old MacBook it was relatively easy to do. sudo launchctl load /System/Library/LaunchDaemons/tftp.plist. The .bin file of the current firmware can then be saved in the /private/tftboot/ directory. Important: you have to rename the firmware file to dut.bin and make it executable with sudo chmod 777.
  4. I connected the gateway to the MacBook using a LAN cable. You have to manually set the IP address of the MacBook and make sure that the gateway and the MacBook (TFTP-server) are in the same subnet.
If everything is correct, the gateway will find the TFTP-server using boot option number two and load the file with the new firmware. Everything takes a certain amount of time until it is fully installed. Not everything worked right away, but my new friend ChatGPT helped me make the right settings. :wink:
Perhaps the above points can help someone who has similar problems with their gateway.
Best regards, Daniel
