Alf
(Andrew Pike)
1
I have a RAK7289C and it periodically keeps resetting the server address to the default
“rak.eu1.cloud.thethings.industries”
Firmware is 1.3.3 and I have wisdm enabled and FOTA enabled. The netowrk settings and frequency are not updated correctly in WisDM either.
What can I do to stop this changing al the time.
Martin
(Martin Manolov)
2
Hello @Alf,
The settings in the WisDM overwrite the settings on the gateway, not the other way around.
You need to set the server address in the WisDM.
Alf
(Andrew Pike)
3
Thanks but I can’t change this in wisdm
Martin
(Martin Manolov)
4
The WisDM does not support custom channel plan, only the LoRaWAN frequency plans.
As for the server address, it can be changed from the Network configuration tab in WisDM:
