RAK 811 Break out Module + esp 32
Hello , I need support to connect ESP32 with my RAK811 Breakout module for Water level Monitoring. I have setup a Pi hat 2245 gateway and connected it to the ttn. I join using ABP mode. A sample code will be helpful to further proceed with the project
You can try the proposed way here How interface RAK811 breakout module with eps32
Welcome to the Rak forum @timothydpaul! It is always best to post here if you have questions so other rakstars can help you. Just follow the link @velev posted above. That is also the library I told you before. But of course, you still have the option to do it yourself without using any libraries. Just send direct at commands.
