I am looking Data format for RAK 811 Tracker node.
I think 811 Tracker node is different than 5205. 811 do not have LIS3DH sensor and BME680 sensor.
This is not much helpful.
Hi @iotvigyan
As it is based on RAK811 it is basically the same. It has LIS3DH sensor! Source code and manuals can be found here RAK Git .
Best regards.
I am using Lora server open source and configuring RAK811 for Cayenne LLP, I am unable to get GPS information in packet. So I am looking decoder script or Data format to create custom script.
Joy !!
Which firmware you use? LPP sends GPS data on fport 1 by default. Pls share screen of payload data and fports. I think i have one on my shelf
i will check this latter.
Hi, I am able to observed the latitude and longitude in fPort=2 . Now I am trying to get this data to be displayed on Grafana Worldmap ?
My db is looking as below:
But I am unable to see any point on MAP !!
Please help.
Hi @iotvigyan,
What DB are you using? Can you share the custom encoder/decoder you are using?
Vladislav
