I have installed raspberryPi Buster Lite on SD card using a RAK-831 gateway and RAK2245_based_on_Raspbian_OS_for_RPI3_V4.1.0_20191202.img
I change the password in RaspberryPi.
What username and password does rak-gateway login: use ? I have used Pi password and Admin etc but I can’t login in to rak-gateway.
When I Install Buster-Lite everything works ok ,login, do SSH and make changes, but when I install RAK-831 gateway and RAK2245_based_on_Raspbian_OS_for_RPI3_V4.1.0_20191202.img then reboot Pi , and it comes up with the rak-gateway login: and won’t accept any uaername or password.
Hi. If yor are using RAK Image for RPi and want to connect via ethernet you have to connect your PC to RPi directly with patch cable. Then set your PC IP to something is same network like PIs - 192.168.10.20 - for example. Then you can ping and SSH to 192.168.10.10
You also can connect to RPi WiFi AP. You will see wireless network with the name RAKwireles_XXX , passowrd is rakwireless. Then the IP is 192.168.230.1
Then the login is default: “pi” for username and “raspberry” for password.
my first time to setup a rak-gateway.
Do you install a SD card with RaspberryPi Buster-lite first and then RAK2245_based_on_Raspbian_OS_for_RPI3_V4.1.0_20191202.img second ?
I have finally got rak-gateway setup, i was doing the installation wrong I got everything setup except doing ssh 192.168.10.10, I want to change my POE ethernet connection to [email protected]. , My gateway Router is 192.168.0.1 , My PC is set to 192.168.0.100. I have changed the Host to rak-gateway on the pi.
What is the name of “config” in the rak-gateway setup. I have searched all over the Internet on how to do this, but with no luck. I guess I’m using the wrong search info.
If I do sudo ifconfig eth0 192.168.0.102 netmask 255.255.255.0 on the rak-gateway it changes the eth0 to 192.168.0.102.
If I do a reboot it changes eth0 back to 192.168.10.10.
And the same if I do a sudo passwd, It changes password, but if I reboot it changes it back to default “raspberry” .
