Hi, I have the 2 items above, and neither will detect a com port (the Arduino 1.8.19 IDE is grayed out when I go to Tools > Port).
I have a dual-boot Windows 7 / Ubuntu 16.04 machine. When I first plugged in the USB connector, it showed that Windows 7 was installing device drivers, but it failed to install the 4631 driver. Since then, it has not reported any driver installation, even after a reboot.
The Linux side does a similar thing, but it reports in the IDE that there is a syntax error when I try to upload the file. Also, I cannot get any response from the AT command set (no echo).
I thought for sure if I purchased 2 separate WisBlock items that at least one of them will work, but neither item is working. Any ideas?
I have studied this forum and I definitely see that other people are having com problems, but I have tried to get it working for 3 days now, so I think I need help.
Regards, Adrian
