Hello)
Does miner RAK Hotspot V2 support Semtech packet forwarder to our network server (for example ChirpStack)?
Can it be used as a Helium miner and as a LoRaWAN gateway at the same time?
Hello)
Hei,
At the same time no, you could do it one at a time. Simplest way would be to plug a new SD card and flash some RAK7248 firmware to it in case you decide to do it:
Vladislav
Hi @Hobo ,
i tried to do so, but the packetforwarder is not starting:
INFO: [main] TTY port /dev/ttyAMA0 open for GPS synchronization
CoreCell reset through GPIO17…
Opening SPI communication interface
Note: chip version is 0x05 (v0.5)
ERROR: Failed to set SX1250_0 in STANDBY_RC mode
ERROR: failed to setup radio 0
ERROR: [main] failed to start the concentrator
Do you know what i can do?
Thank you
