Thank you Velev –
I was able to bring up Tap0 now. I imported the .ovpn file into OpenVPN GUI. When I try to connect from my laptop, it shows the below. What do you think is causing the problems? I cannot connect, the client never connects and turns green.
Is there something easy I missed?
Jeff
Fri Oct 23 01:14:29 2020 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless “allow-compression yes” is also set.
Fri Oct 23 01:14:29 2020 --cipher is not set. Previous OpenVPN version defaulted to BF-CBC as a fallback when cipher negotiation failed in this case. If you need this fallback please add ‘–data-ciphers-fallback BF-CBC’ to your configuration and/or add BF-CBC to --data-ciphers.
Fri Oct 23 01:14:29 2020 OpenVPN 2.5_rc2 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Sep 30 2020
Fri Oct 23 01:14:29 2020 Windows version 10.0 (Windows 10 or greater) 64bit
Fri Oct 23 01:14:29 2020 library versions: OpenSSL 1.1.1h 22 Sep 2020, LZO 2.10
Fri Oct 23 01:14:29 2020 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Fri Oct 23 01:14:29 2020 Need hold release from management interface, waiting…
Fri Oct 23 01:14:30 2020 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Fri Oct 23 01:14:30 2020 MANAGEMENT: CMD ‘state on’
Fri Oct 23 01:14:30 2020 MANAGEMENT: CMD ‘log all on’
Fri Oct 23 01:14:30 2020 MANAGEMENT: CMD ‘echo all on’
Fri Oct 23 01:14:30 2020 MANAGEMENT: CMD ‘bytecount 5’
Fri Oct 23 01:14:30 2020 MANAGEMENT: CMD ‘hold off’
Fri Oct 23 01:14:30 2020 MANAGEMENT: CMD ‘hold release’
Fri Oct 23 01:14:30 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]64.225.88.83:1194
Fri Oct 23 01:14:30 2020 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Oct 23 01:14:30 2020 UDP link local: (not bound)
Fri Oct 23 01:14:30 2020 UDP link remote: [AF_INET]64.225.88.83:1194
Fri Oct 23 01:14:30 2020 MANAGEMENT: >STATE:1603433670,WAIT,
Fri Oct 23 01:15:31 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Oct 23 01:15:31 2020 TLS Error: TLS handshake failed
Fri Oct 23 01:15:31 2020 SIGUSR1[soft,tls-error] received, process restarting
Fri Oct 23 01:15:31 2020 MANAGEMENT: >STATE:1603433731,RECONNECTING,tls-error,
Fri Oct 23 01:15:31 2020 Restart pause, 5 second(s)
Fri Oct 23 01:15:36 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]64.225.88.83:1194
Fri Oct 23 01:15:36 2020 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Oct 23 01:15:36 2020 UDP link local: (not bound)
Fri Oct 23 01:15:36 2020 UDP link remote: [AF_INET]64.225.88.83:1194
Fri Oct 23 01:15:36 2020 MANAGEMENT: >STATE:1603433736,WAIT,
Fri Oct 23 01:16:36 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Oct 23 01:16:36 2020 TLS Error: TLS handshake failed
Fri Oct 23 01:16:36 2020 SIGUSR1[soft,tls-error] received, process restarting
Fri Oct 23 01:16:36 2020 MANAGEMENT: >STATE:1603433796,RECONNECTING,tls-error,
Fri Oct 23 01:16:36 2020 Restart pause, 5 second(s)
Fri Oct 23 01:16:41 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]64.225.88.83:1194
Fri Oct 23 01:16:41 2020 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Oct 23 01:16:41 2020 UDP link local: (not bound)
Fri Oct 23 01:16:41 2020 UDP link remote: [AF_INET]64.225.88.83:1194
Fri Oct 23 01:16:41 2020 MANAGEMENT: >STATE:1603433801,WAIT,
Fri Oct 23 01:17:41 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Oct 23 01:17:41 2020 TLS Error: TLS handshake failed
Fri Oct 23 01:17:41 2020 SIGUSR1[soft,tls-error] received, process restarting
Fri Oct 23 01:17:41 2020 MANAGEMENT: >STATE:1603433861,RECONNECTING,tls-error,
Fri Oct 23 01:17:41 2020 Restart pause, 5 second(s)
Fri Oct 23 01:17:46 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]64.225.88.83:1194
Fri Oct 23 01:17:46 2020 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Oct 23 01:17:46 2020 UDP link local: (not bound)
Fri Oct 23 01:17:46 2020 UDP link remote: [AF_INET]64.225.88.83:1194
Fri Oct 23 01:17:46 2020 MANAGEMENT: >STATE:1603433866,WAIT,
