RAK wisblock 4631 shows corrupted boot loader
RAK4631
I have a slow blinking green light (throbbing?), after modifying a setting on the device in Meshtastic. Hoping you have a RAK image I can flash it with to restore the corrupted boot loader.
during boot I get this error on the serial console:
lfs error:493: Corrupted dir pair at 19 18
I tried to flash the Bootloader using nRF Connect Programmer and the bootloader.hex from the RAK github site, but Programmer says its it not in MCUBoot and theres nothing it can do to communicate.
The serial terminal will connect, and get the boot load sequence seen below, but it doesn’t respond when I run commands like 'AT+DFU, ‘AT+FORMAT’ or ‘AT+RESET’
Is there a RAK tool I missed to just get it back to ‘factory’?
Thanks!
Serial Connection view during attempted boot:
@INFO | ??:??:?? 0
//\ E S H T /\ S T / C
DEBUG | ??:??:?? 0 Filesystem files:
DEBUG | ??:??:?? 0 prefs (directory)
DEBUG | ??:??:?? 0 config.proto (166 Bytes)
DEBUG | ??:??:?? 0 channels.proto (57 Bytes)
DEBUG | ??:??:?? 0 db.proto (347 Bytes)
DEBUG | ??:??:?? 0 Power::lipoInit lipo sensor is not ready yet
DEBUG | ??:??:?? 0 Use analog input 5 for battery level
INFO | ??:??:?? 0 Scan for i2c devices
DEBUG | ??:??:?? 0 Scan for I2C devices on port 1
INFO | ??:??:?? 0 No I2C devices found
DEBUG | ??:??:?? 0 acc_info = 0
INFO | ??:??:?? 0 S:B:9,2.5.18.89ebafc
INFO | ??:??:?? 0 Build timestamp: 1735423672
DEBUG | ??:??:?? 0 Reset reason: 0x0
DEBUG | ??:??:?? 0 Set random seed 2275464391
INFO | ??:??:?? 0 Init NodeDB
INFO | ??:??:?? 0 Load /prefs/db.proto
ERROR | ??:??:?? 0 LFS assert: head >= 2 && head <= lfs->cfg->block_count
ERROR | ??:??:?? 0 Trying FSCom.format()
AT+DFU
  • What firmware version? Can it be obtained with AT+VER=
    I can make a serial connection, but it fails to respond
  • Windows 11, latest build
  • It is stuck 100% of the time. I can double click the reset button and get it to enter DFU mode on my PC as a mapped drive, and drag over a fw image, but it doesnt flash it correctly.
  • How can we replicate the problem? Happens every time I give the device power.
  • Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
    I know you don’t support mashtastic, was hoping you could point me to a tool or image at RAK that I could use to get it back into working order.
    I’m going to try the procedure from WisBlock/bootloader/RAK4630 at master · RAKWireless/WisBlock · GitHub
    but like I said, every time I try to flash it in DFU mode, it attempts to reboot and fails.
I have access to multiple linux machines, if you think that might give me a better outcome. I also tried multiple different USB cables.
Welcome to the forum @brickedUp
Your log
says that your device is booting normally, but there is something messed up with the Meshtastic firmware or its settings.
Try to double push the RESET button while connected to a computer over USB, it should show up as external drive?
Flash the attached Hardware Test Firmware and let it run. Check the output it gives over the USB port and share here.
Then put the device into UF2 mode again by double push the RESET button. Then try to copy the Meshtastic firmware again.
We are not developing or maintaining the Meshtastic firmware. For problems with the Meshtastic firmware, please contact Meshtastic directly.
Unzip the UF2 file from the ZIP file.
Double push RESET button to see an external drive RAK4631
Copy the UF2 file to the external drive RAK4631
WB_HW_Test_V1.1.8.uf2.zip (186.4 KB)
