may be somebody can help me with my RAK10701-P field tester.
After first time of usage and several tries to connect with WisToolBox, I made as a first step a firmware update. Since this has been done the device is still reachable via WisToolBox, but the display is not working anymore. And I can not bring it back to life.
Is it possible, that I used the wrong firmware? Has been proposed by WisToolBox, but now I´m not sure anymore. According to the device the firmware RUI_4.0.6_RAK4631 is installed. A bit confusing, because the device has been identified as a RAK4630, but …
Any suggestions, what I can do to reanimate the display?
But another question. The device joined our network, I can see it in my log, but it´s a custumed network. Means it is not TTN or Helium. Unfortunately the device does not show any measurements (rssi, distance, etc.). All fields are empty although it is connected. May be I made somethin wrong again?
Hi @carlrowan, I have to correct myself. Our service provider is using a chirpstack server. And meanwhile I’ve checked both, WisToolBox and the device. It looks strange.
Display of RAK10701: No Gateway, all fields empty
WisToolBox: LoRaWAN, RSSI -27dBm, SNR 5 dBm
Any ideas what could be the reason for the differents?
