I am trying to get RAK10701 node working on ChirpStack server following this Quickstart.
I ran into few small problems in the guide itself:
In the decoder JS which goes into the Codec on Chirpstack side, there is last “]” missing in the end
There is alternative decode script on github where “,” is missing in the function parameter (between bytes and variables)
While declaring the fields on DataCake, it is also needed to add NUM_GW (integer), otherwise downlink decoder JS not working
chirpstack v4 expects decodeUplink now instead of decode, so I have added below part on top of main Decode function
function decodeUplink(input) {
return {
data: Decode(input.fPort, input.bytes, input.variables)
Finally I managed to get the downlink scheduled and sent from DataCake. (Guide says that node expects it to be on fport 2, I have tried the same on port 1 as well)
I can see that payload is correct
However I am not getting anything on the RAK10701 side, no data (f.eg No.of Gateways shows “–”)
I am sure I have followed the guide precisely.
What can be next step of troubleshooting?
thanks
Sergi
