Good morning,
I am having problems to see the RAK10701-P payload in the TTNV3 and TagoIO. What I have to expect about the payload in both environment? In the beginning I was thinking that the problem was located in the Decoder, but in fact, I am not sure that the payload is reaching TTNV3 and TagoIO. Why? Because I am not seeing the payload in the TTNV3/TagoIO uplink message area.
Could you help me?
Claudio
2023-03-13 07:10:18: [POST] HTTP Request: From: 52.7.225.66 [TagoIO-SDK|JS|10.7.6 (External; Node.js/v16.14.2 linux/arm64)] - Content-Type: application/json - Token Ending: 64151
2023-03-13 07:10:18: Raw payload: [{"variable":"ttn_payload_v3","value":"{\"end_device_ids\":{\"dev_eui\":\"AC1F09FFFE08E7AF\",\"device_id\":\"eui-ac1f09fffe08e7af\",\"application_ids\":{\"application_id\":\"rakwireless-field-tester\"},\"join_eui\":\"AC1F09FFF9150701\",\"dev_addr\":\"260B3854\"},\"uplink_message\":{\"frm_payload\":\"0D8FnssCBAcOCg==\",\"f_port\":1,\"f_cnt\":8,\"session_key_id\":\"AYbacTizO3mRnBhgTF76hw==\",\"decoded_payload\":{},\"rx_metadata\":[{\"gateway_ids\":{\"gateway_id\":\"brrjnasondasgw01\",\"eui\":\"60C5A8FFFE74D380\"},\"time\":\"2023-03-13T10:10:17.409550905Z\",\"timestamp\":1249980580,\"rssi\":-6,\"channel_rssi\":-6,\"snr\":10,\"location\":{\"latitude\":-22.998018054874855,\"longitude\":-43.38812005529691,\"altitude\":5,\"source\":\"SOURCE_REGISTRY\"},\"uplink_token\":\"Ch4KHAoQYnJyam5hc29uZGFzZ3cwMRIIYMWo//5004AQpOGE1AQaDAiK7bugBhDf88DYASCggZjFsP81\",\"received_at\":\"2023-03-13T10:10:18.352763233Z\"}],\"settings\":{\"data_rate\":{\"lora\":{\"bandwidth\":125000,\"spreading_factor\":7,\"coding_rate\":\"4/5\"}},\"frequency\":\"916600000\",\"timestamp\":1249980580,\"time\":\"2023-03-13T10:10:17.409550905Z\"},\"received_at\":\"2023-03-13T10:10:18.547532606Z\",\"confirmed\":true,\"consumed_airtime\":\"0.061696s\",\"locations\":{\"frm-payload\":{\"latitude\":-22.9977737,\"longitude\":-43.3880857,\"altitude\":44,\"source\":\"SOURCE_GPS\"}},\"network_ids\":{\"net_id\":\"000013\",\"tenant_id\":\"ttn\",\"cluster_id\":\"eu1\",\"cluster_address\":\"eu1.cloud.thethings.network\"}},\"correlation_ids\":[\"as:up:01GVD763G33WE5K8SMYCZ6H3T7\",\"gs:conn:01GV64PY0FN9H2EKQJ1K7J4PYV\",\"gs:up:host:01GV64PY0RJ82TYRA4G5JAHG6B\",\"gs:uplink:01GVD76374R3YBNT4C972DQH9M\",\"ns:uplink:01GVD7639KFVJ1FGBNG5700JXN\",\"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01GVD7639KAG82FEHE6RT5RT9F\",\"rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01GVD763G3MB0EG07XZ15FFWED\"],\"received_at\":\"2023-03-13T10:10:18.755683173Z\"}","group":"1678702218842"}]
2023-03-13 07:10:18: Result of [LoRaWAN TTI/TTN v3] payload parser: [{"variable":"lora_bandwidth","value":125000,"group":"1678702218842","serie":"1678702218842"},{"variable":"lora_spreading_factor","value":7,"group":"1678702218842","serie":"1678702218842"},{"variable":"lora_coding_rate","value":"4/5","group":"1678702218842","serie":"1678702218842"},{"variable":"frequency","value":"916600000","group":"1678702218842","serie":"1678702218842"},{"variable":"timestamp","value":1249980580,"group":"1678702218842","serie":"1678702218842"},{"variable":"time","value":"2023-03-13T10:10:17.409550905Z","group":"1678702218842","serie":"1678702218842"},{"variable":"device_id","value":"eui-ac1f09fffe08e7af","group":"1678702218842","serie":"1678702218842"},{"variable":"application_id","value":"rakwireless-field-tester","group":"1678702218842","serie":"1678702218842"},{"variable":"fport","value":1,"group":"1678702218842","serie":"1678702218842"},{"variable":"fcnt","value":8,"group":"1678702218842","serie":"1678702218842"},{"variable":"payload","value":"d03f059ecb0204070e0a","group":"1678702218842","serie":"1678702218842"},{"variable":"gateway_eui","value":"60C5A8FFFE74D380","group":"1678702218842","serie":"1678702218842"},{"variable":"rssi","value":-6,"group":"1678702218842","serie":"1678702218842"},{"variable":"snr","value":10,"group":"1678702218842","serie":"1678702218842"},{"variable":"gateway_location","value":"-22.998018054874855,-43.38812005529691","group":"1678702218842","location":{"lat":-22.998018054874855,"lng":-43.38812005529691},"serie":"1678702218842"}]
2023-03-13 07:10:18: Result of [RAK10701-P] payload parser: [{"variable":"lora_bandwidth","value":125000,"group":"1678702218842","serie":"1678702218842"},{"variable":"lora_spreading_factor","value":7,"group":"1678702218842","serie":"1678702218842"},{"variable":"lora_coding_rate","value":"4/5","group":"1678702218842","serie":"1678702218842"},{"variable":"frequency","value":"916600000","group":"1678702218842","serie":"1678702218842"},{"variable":"timestamp","value":1249980580,"group":"1678702218842","serie":"1678702218842"},{"variable":"time","value":"2023-03-13T10:10:17.409550905Z","group":"1678702218842","serie":"1678702218842"},{"variable":"device_id","value":"eui-ac1f09fffe08e7af","group":"1678702218842","serie":"1678702218842"},{"variable":"application_id","value":"rakwireless-field-tester","group":"1678702218842","serie":"1678702218842"},{"variable":"fport","value":1,"group":"1678702218842","serie":"1678702218842"},{"variable":"fcnt","value":8,"group":"1678702218842","serie":"1678702218842"},{"variable":"payload","value":"d03f059ecb0204070e0a","group":"1678702218842","serie":"1678702218842"},{"variable":"gateway_eui","value":"60C5A8FFFE74D380","group":"1678702218842","serie":"1678702218842"},{"variable":"rssi","value":-6,"group":"1678702218842","serie":"1678702218842"},{"variable":"snr","value":10,"group":"1678702218842","serie":"1678702218842"},{"variable":"gateway_location","value":"-22.998018054874855,-43.38812005529691","group":"1678702218842","location":{"lat":-22.998018054874855,"lng":-43.38812005529691},"serie":"1678702218842"}]
2023-03-13 07:10:18: Bucket [2aae]: 15 Data Added
2023-03-13 07:10:03: [POST] HTTP Request: From: 52.7.225.66 [TagoIO-SDK|JS|10.7.6 (External; Node.js/v16.14.2 linux/arm64)] - Content-Type: application/json - Token Ending: 64151
2023-03-13 07:10:03: Raw payload: [{"variable":"ttn_payload_v3","value":"{\"end_device_ids\":{\"dev_eui\":\"AC1F09FFFE08E7AF\",\"device_id\":\"eui-ac1f09fffe08e7af\",\"application_ids\":{\"application_id\":\"rakwireless-field-tester\"},\"join_eui\":\"AC1F09FFF9150701\",\"dev_addr\":\"260B3854\"},\"uplink_message\":{\"frm_payload\":\"0D8HnssDBAELCw==\",\"f_port\":1,\"f_cnt\":7,\"session_key_id\":\"AYbacTizO3mRnBhgTF76hw==\",\"decoded_payload\":{},\"rx_metadata\":[{\"gateway_ids\":{\"gateway_id\":\"brrjnasondasgw01\",\"eui\":\"60C5A8FFFE74D380\"},\"time\":\"2023-03-13T10:10:02.417896986Z\",\"timestamp\":1234980603,\"rssi\":-8,\"channel_rssi\":-8,\"snr\":8,\"location\":{\"latitude\":-22.998018054874855,\"longitude\":-43.38812005529691,\"altitude\":5,\"source\":\"SOURCE_REGISTRY\"},\"uplink_token\":\"Ch4KHAoQYnJyam5hc29uZGFzZ3cwMRIIYMWo//5004AQ+53xzAQaDAj77LugBhDtj6GMASD4iNLU+P41\",\"received_at\":\"2023-03-13T10:10:03.192974310Z\"}],\"settings\":{\"data_rate\":{\"lora\":{\"bandwidth\":125000,\"spreading_factor\":7,\"coding_rate\":\"4/5\"}},\"frequency\":\"915600000\",\"timestamp\":1234980603,\"time\":\"2023-03-13T10:10:02.417896986Z\"},\"received_at\":\"2023-03-13T10:10:03.295154111Z\",\"confirmed\":true,\"consumed_airtime\":\"0.061696s\",\"locations\":{\"frm-payload\":{\"latitude\":-22.9977737,\"longitude\":-43.3880857,\"altitude\":44,\"source\":\"SOURCE_GPS\"}},\"network_ids\":{\"net_id\":\"000013\",\"tenant_id\":\"ttn\",\"cluster_id\":\"eu1\",\"cluster_address\":\"eu1.cloud.thethings.network\"}},\"correlation_ids\":[\"as:up:01GVD75MKC8RJSXE0QDM2QS2P8\",\"gs:conn:01GV64PY0FN9H2EKQJ1K7J4PYV\",\"gs:up:host:01GV64PY0RJ82TYRA4G5JAHG6B\",\"gs:uplink:01GVD75MCYAW2P85QFNKJT3KNF\",\"ns:uplink:01GVD75MCZCQVBD1C6ARXMG721\",\"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01GVD75MCZ9FPAMQERYTHG141T\",\"rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01GVD75MKB6M882VF2A1R8JX88\"],\"received_at\":\"2023-03-13T10:10:03.499581670Z\"}","group":"1678702203576"}]
2023-03-13 07:10:03: Result of [LoRaWAN TTI/TTN v3] payload parser: [{"variable":"lora_bandwidth","value":125000,"group":"1678702203576","serie":"1678702203576"},{"variable":"lora_spreading_factor","value":7,"group":"1678702203576","serie":"1678702203576"},{"variable":"lora_coding_rate","value":"4/5","group":"1678702203576","serie":"1678702203576"},{"variable":"frequency","value":"915600000","group":"1678702203576","serie":"1678702203576"},{"variable":"timestamp","value":1234980603,"group":"1678702203576","serie":"1678702203576"},{"variable":"time","value":"2023-03-13T10:10:02.417896986Z","group":"1678702203576","serie":"1678702203576"},{"variable":"device_id","value":"eui-ac1f09fffe08e7af","group":"1678702203576","serie":"1678702203576"},{"variable":"application_id","value":"rakwireless-field-tester","group":"1678702203576","serie":"1678702203576"},{"variable":"fport","value":1,"group":"1678702203576","serie":"1678702203576"},{"variable":"fcnt","value":7,"group":"1678702203576","serie":"1678702203576"},{"variable":"payload","value":"d03f079ecb0304010b0b","group":"1678702203576","serie":"1678702203576"},{"variable":"gateway_eui","value":"60C5A8FFFE74D380","group":"1678702203576","serie":"1678702203576"},{"variable":"rssi","value":-8,"group":"1678702203576","serie":"1678702203576"},{"variable":"snr","value":8,"group":"1678702203576","serie":"1678702203576"},{"variable":"gateway_location","value":"-22.998018054874855,-43.38812005529691","group":"1678702203576","location":{"lat":-22.998018054874855,"lng":-43.38812005529691},"serie":"1678702203576"}]
2023-03-13 07:10:03: Result of [RAK10701-P] payload parser: [{"variable":"lora_bandwidth","value":125000,"group":"1678702203576","serie":"1678702203576"},{"variable":"lora_spreading_factor","value":7,"group":"1678702203576","serie":"1678702203576"},{"variable":"lora_coding_rate","value":"4/5","group":"1678702203576","serie":"1678702203576"},{"variable":"frequency","value":"915600000","group":"1678702203576","serie":"1678702203576"},{"variable":"timestamp","value":1234980603,"group":"1678702203576","serie":"1678702203576"},{"variable":"time","value":"2023-03-13T10:10:02.417896986Z","group":"1678702203576","serie":"1678702203576"},{"variable":"device_id","value":"eui-ac1f09fffe08e7af","group":"1678702203576","serie":"1678702203576"},{"variable":"application_id","value":"rakwireless-field-tester","group":"1678702203576","serie":"1678702203576"},{"variable":"fport","value":1,"group":"1678702203576","serie":"1678702203576"},{"variable":"fcnt","value":7,"group":"1678702203576","serie":"1678702203576"},{"variable":"payload","value":"d03f079ecb0304010b0b","group":"1678702203576","serie":"1678702203576"},{"variable":"gateway_eui","value":"60C5A8FFFE74D380","group":"1678702203576","serie":"1678702203576"},{"variable":"rssi","value":-8,"group":"1678702203576","serie":"1678702203576"},{"variable":"snr","value":8,"group":"1678702203576","serie":"1678702203576"},{"variable":"gateway_location","value":"-22.998018054874855,-43.38812005529691","group":"1678702203576","location":{"lat":-22.998018054874855,"lng":-43.38812005529691},"serie":"1678702203576"}]
2023-03-13 07:10:03: Bucket [2aae]: 15 Data Added
2023-03-13 07:09:48: [POST] HTTP Request: From: 52.7.225.66 [TagoIO-SDK|JS|10.7.6 (External; Node.js/v16.14.2 linux/arm64)] - Content-Type: application/json - Token Ending: 64151
2023-03-13 07:09:48: Raw payload: [{"variable":"ttn_payload_v3","value":"{\"end_device_ids\":{\"dev_eui\":\"AC1F09FFFE08E7AF\",\"device_id\":\"eui-ac1f09fffe08e7af\",\"application_ids\":{\"application_id\":\"rakwireless-field-tester\"},\"join_eui\":\"AC1F09FFF9150701\",\"dev_addr\":\"260B3854\"},\"uplink_message\":{\"frm_payload\":\"0D8IHssDBAMLCg==\",\"f_port\":1,\"f_cnt\":6,\"session_key_id\":\"AYbacTizO3mRnBhgTF76hw==\",\"decoded_payload\":{},\"rx_metadata\":[{\"gateway_ids\":{\"gateway_id\":\"brrjnasondasgw01\",\"eui\":\"60C5A8FFFE74D380\"},\"time\":\"2023-03-13T10:09:47.427160024Z\",\"timestamp\":1219980548,\"rssi\":-5,\"channel_rssi\":-5,\"snr\":8.5,\"location\":{\"latitude\":-22.998018054874855,\"longitude\":-43.38812005529691,\"altitude\":5,\"source\":\"SOURCE_REGISTRY\"},\"uplink_token\":\"Ch4KHAoQYnJyam5hc29uZGFzZ3cwMRIIYMWo//5004AQhNrdxQQaDAjs7LugBhCq08uIASCgr4fkwP41\",\"received_at\":\"2023-03-13T10:09:48.185282467Z\"}],\"settings\":{\"data_rate\":{\"lora\":{\"bandwidth\":125000,\"spreading_factor\":7,\"coding_rate\":\"4/5\"}},\"frequency\":\"916200000\",\"timestamp\":1219980548,\"time\":\"2023-03-13T10:09:47.427160024Z\"},\"received_at\":\"2023-03-13T10:09:48.287407812Z\",\"confirmed\":true,\"consumed_airtime\":\"0.061696s\",\"locations\":{\"frm-payload\":{\"latitude\":-22.9977737,\"longitude\":-43.3880857,\"altitude\":44,\"source\":\"SOURCE_GPS\"}},\"network_ids\":{\"net_id\":\"000013\",\"tenant_id\":\"ttn\",\"cluster_id\":\"eu1\",\"cluster_address\":\"eu1.cloud.thethings.network\"}},\"correlation_ids\":[\"as:up:01GVD755YCFZJMP5MFG4Y0J7B2\",\"gs:conn:01GV64PY0FN9H2EKQJ1K7J4PYV\",\"gs:up:host:01GV64PY0RJ82TYRA4G5JAHG6B\",\"gs:uplink:01GVD755QYX1T52TPFN44V42V5\",\"ns:uplink:01GVD755QZD6JX35MMFFJM6JJA\",\"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01GVD755QZR0J61MVDXPER49W6\",\"rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01GVD755YBVGPKTCN5X7C61GPT\"],\"received_at\":\"2023-03-13T10:09:48.491616851Z\"}","group":"1678702188573"}]
2023-03-13 07:09:48: Result of [LoRaWAN TTI/TTN v3] payload parser: [{"variable":"lora_bandwidth","value":125000,"group":"1678702188573","serie":"1678702188573"},{"variable":"lora_spreading_factor","value":7,"group":"1678702188573","serie":"1678702188573"},{"variable":"lora_coding_rate","value":"4/5","group":"1678702188573","serie":"1678702188573"},{"variable":"frequency","value":"916200000","group":"1678702188573","serie":"1678702188573"},{"variable":"timestamp","value":1219980548,"group":"1678702188573","serie":"1678702188573"},{"variable":"time","value":"2023-03-13T10:09:47.427160024Z","group":"1678702188573","serie":"1678702188573"},{"variable":"device_id","value":"eui-ac1f09fffe08e7af","group":"1678702188573","serie":"1678702188573"},{"variable":"application_id","value":"rakwireless-field-tester","group":"1678702188573","serie":"1678702188573"},{"variable":"fport","value":1,"group":"1678702188573","serie":"1678702188573"},{"variable":"fcnt","value":6,"group":"1678702188573","serie":"1678702188573"},{"variable":"payload","value":"d03f081ecb0304030b0a","group":"1678702188573","serie":"1678702188573"},{"variable":"gateway_eui","value":"60C5A8FFFE74D380","group":"1678702188573","serie":"1678702188573"},{"variable":"rssi","value":-5,"group":"1678702188573","serie":"1678702188573"},{"variable":"snr","value":8.5,"group":"1678702188573","serie":"1678702188573"},{"variable":"gateway_location","value":"-22.998018054874855,-43.38812005529691","group":"1678702188573","location":{"lat":-22.998018054874855,"lng":-43.38812005529691},"serie":"1678702188573"}]
2023-03-13 07:09:48: Result of [RAK10701-P] payload parser: [{"variable":"lora_bandwidth","value":125000,"group":"1678702188573","serie":"1678702188573"},{"variable":"lora_spreading_factor","value":7,"group":"1678702188573","serie":"1678702188573"},{"variable":"lora_coding_rate","value":"4/5","group":"1678702188573","serie":"1678702188573"},{"variable":"frequency","value":"916200000","group":"1678702188573","serie":"1678702188573"},{"variable":"timestamp","value":1219980548,"group":"1678702188573","serie":"1678702188573"},{"variable":"time","value":"2023-03-13T10:09:47.427160024Z","group":"1678702188573","serie":"1678702188573"},{"variable":"device_id","value":"eui-ac1f09fffe08e7af","group":"1678702188573","serie":"1678702188573"},{"variable":"application_id","value":"rakwireless-field-tester","group":"1678702188573","serie":"1678702188573"},{"variable":"fport","value":1,"group":"1678702188573","serie":"1678702188573"},{"variable":"fcnt","value":6,"group":"1678702188573","serie":"1678702188573"},{"variable":"payload","value":"d03f081ecb0304030b0a","group":"1678702188573","serie":"1678702188573"},{"variable":"gateway_eui","value":"60C5A8FFFE74D380","group":"1678702188573","serie":"1678702188573"},{"variable":"rssi","value":-5,"group":"1678702188573","serie":"1678702188573"},{"variable":"snr","value":8.5,"group":"1678702188573","serie":"1678702188573"},{"variable":"gateway_location","value":"-22.998018054874855,-43.38812005529691","group":"1678702188573","location":{"lat":-22.998018054874855,"lng":-43.38812005529691},"serie":"1678702188573"}]
2023-03-13 07:09:48: Bucket [2aae]: 15 Data Added
