I can program STM32 using Arduino IDE and also restore default firmware: RAK11160_latest_final.hex (ST LINK, STM32CubeProgrammer)
RAK11160_latest.bin (RAK_Device_Firmware_Upgrade_Tool_v1.4)
I can not use BLE or WIFI by AT commands:
AT+VER=?
AT+VER=RUI_4.2.2_RAK11160
AT+BLEINIT?
AT_COMMAND_NOT_FOUND
AT
OK
AT+CWINIT?
AT
OK
RAK11160 has ESP32C2 inside which has limited memory space. By default, the FW in it only works on WiFi functionality. I am still checking with the team the compatible BLE but take note that you cannot make them work simultaneously, the Espressif FW for ESP32C2 has one dedicated for WiFi functionality and one for BLE.
If you need both WiFi and BLE simultaneously in your usecase, a more powerful chip might be needed, the ESP32S3 inside RAK3112.
Please reread my post. I don’t want to use them simultaneously. I want to use one of them. Both failed to respond to the AT command as described above. Could you help?
You can pass-thru an AT command to the ESP32C2 by sending AT+ESP=1.
To ensure that it is active, you can send AT+ESPPOWER=1. The latter command pull down the reset pin of internally if the value is 0 making the ESP32C2 in inactive state.
below is the result of my last attempt 40,41 (ST_PA2/ST_UART2_TX, ST_PA3/ST_UART2_RX):
AT
OK
AT+VER=?
OK
AT+ESP=1
OK
ready
Unfortunately, after the AT+ESP=1 command, the device stopped responding. I tried sending the AT+ESPOWER=1 command, but received no response.
I rewired UART to 30, 31 (ESP_GPIO19/ESP_UART_RX, ESP_GPIO20/ESP_UART_TX) when I changed PA0=LOW → PA0=HIGH I get the following response (30,31) at baud=74880:
When you sent AT+ESP=1, you got a ready reply which coming from the ESP32C2 inside RAK11160. This means AT commands of RUI3 will not work anymore but the AT commands of ESP32. To go back to RUI3 AT Commands, you need to send AT+ESP=0.
Currently, does it reply to RUI3 AT commands? But not on ESP32? Or it does not reply to any commands at all? AT+ESP=0 should allow RUI3 AT commands at 115200 baudrate. Also, please ensure that the UART wirings are stable.
After power restart it reply to RUI3 AT commands. After AT+ESP=1 it responds
OK
ready
After that it does not respond to any commands at all (regardless of the baud rate).
