RAK11160 - Com Port Drop Out Issues
Hi All,
RAK11160:
Firmware Version: RUI_4.2.1_RAK11160
AT Command Version: 1.5.14
RUI API Version: 3.2.11
Model ID: rak11160
Hardware ID: stm32wle5xx
Battery Level: 3.000000
Using Version 4.2.4 In Arduino
I notice when I download following code, there are random Serial Port dropouts, com port connects and disconnect on random basis. I am connected with RAK11160 via ST_UART2.
#define BLYNK_AUTH_TOKEN "ABC"
char esp_com_buff[512];
bool wait_ok_response(time_t timeout, char *wait_for = (char *)"OK")
	time_t start = millis();
	int buff_idx = 0;
	memset(esp_com_buff, 0, 512);
	while ((millis() - start) < timeout)
		if (Serial1.available() != 0)
			char rcvd = Serial1.read();
			esp_com_buff[buff_idx] = rcvd;
			buff_idx++;
			if (buff_idx == 512) return false;
			if (strstr(esp_com_buff, wait_for) != NULL) return true;
		delay(100);
	return false;
void setup()
	delay(2000);
	Serial.println("=== Blynk MQTT Test ===");
	Serial1.begin(115200);
	pinMode(PA0, OUTPUT);
	digitalWrite(PA0, HIGH);
	// Probe ESP8684
	while ((millis() - start) < 30000)
		Serial1.println("AT");
		Serial1.flush();
		if (wait_ok_response(10000))
			Serial.println("ESP8684 found");
			break;
		delay(500);
	// Step 1 - MQTT user config
	snprintf(esp_com_buff, 511, "AT+MQTTUSERCFG=0,1,\"\",\"device\",\"%s\",0,0,\"\"\r\n", BLYNK_AUTH_TOKEN);
	Serial1.printf("%s", esp_com_buff);
	Serial1.flush();
		Serial.println("MQTT user config OK");
	else
		Serial.println("MQTT user config failed");
		return;
	// Step 2 - Connect to Blynk MQTT broker
	snprintf(esp_com_buff, 511, "AT+MQTTCONN=0,\"sgp1.blynk.cloud\",1883,0\r\n");
	Serial1.flush();
	Serial.println("Connecting to Blynk...");
		Serial.println("Blynk MQTT connected!");
	else
		Serial.println("Blynk MQTT failed");
		Serial.printf("Response: %s\n", esp_com_buff);
void loop()
Too many com port drop outs and I get following error while downloading:
Detecting baudrate.Traceback (most recent call last):
File “uploader_ymodem.py”, line 910, in
File “”, line 886, in
File “”, line 842, in detect_baudrate
File “serial\serialwin32.py”, line 259, in in_waiting
serial.serialutil.SerialException: ClearCommError failed (PermissionError(13, ‘Access is denied.’, None, 5))
[20036] Failed to execute script ‘uploader_ymodem’ due to unhandled exception!
Failed uploading: uploading error: exit status 1
Hi @omerattiqahmed ,
The issues seems on the COM port communication.
Few things to check/try.
  1. Use a different USB cable or try to different PC just to isolate if issue is related to physical hardware/connection.
  2. Check if other software is trying to use the same COM port number.
  3. Try to disable/enable the COM port in device manager or you can also change the COM port number on the advance settings in device manager.
  4. If you are not using a core board, try a different USB-Serial converter.
The issue is not yet on the module. It is still on establishing connection to PC.
