I’ve been happily coding away in platformio and the RAK11200 module (esp32).
I’ve done this with the following platformio.ini config:
[env:rak11200]
platform = espressif32
board = wiscore_rak11200
framework = arduino
monitor_speed = 115200
board_build.filesystem = littlefs
lib_deps =
https://github.com/Aircoookie/ESPAsyncWebServer.git
bblanchon/ArduinoJson@^7.0.4
I’ve been trying to do something with a captive portal, and thus i’m using DNSServer.h. This doesn’t seem to work and i found that the version of DNSServer.h that i have locally, is very different than the version linked.
My version is located in ~/.platformio/packages/framework-arduinoespressif32/libraries/DNSServer/serc/DNSServer.h and using WiFiUdp.h instead of AsyncUDP.h as in the linked file.
I found that i can change the framework in the config like so:
framework = arduino @ 2.0.16
I believe this is the last stable version, but it produces this error message:
Error: This board doesn't support arduino @ 2.0.16 framework!
Now, i’m surely not an expert in this, and what i linked above is probably the IDF version of things. I’m however just wondering how these versions work and how it fits together, and how i can make sure i’m using “the latest and greatest”.
