I just got a shipment of RAK11200 modules so that we can test WiFi connectivity with our application. I’ve installed the BSP in Arduino IDE and I’m trying to upload my sketch. I’ve shorted BOOT0 and GND pins and pressed reset prior to the compile + upload step and this is what I get:
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32-D0WD-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 34:94:54:bf:c2:f8
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
A fatal error occurred: Invalid head of packet (0xE0)
Failed uploading: uploading error: exit status 2
