SamSkjord
(Sam Conway)
January 3, 2024, 9:21pm
1
Hi, I’m trying to read the state of two relays using a RAK11310 mounted to a RAK19010 without success.
I’ve been using the sketch below to troubleshoot,
The relays are connected between pins IO1\IO2 and ground but always return a state of 0, I added the analog input to further troubleshoot and that always returns 1, this happens even if I set the digitalWrites to LOW.
void setup() {
time_t timeout = millis();
while (!Serial) {
if ((millis() - timeout) < 5000) {
delay(100);
} else {
break;
Serial.println("hi");
pinMode(WB_A0, INPUT);
pinMode(WB_IO1, INPUT);
pinMode(WB_IO2, INPUT);
digitalWrite(WB_A0, HIGH);
digitalWrite(WB_IO1, HIGH);
digitalWrite(WB_IO2, HIGH);
void loop() {
int WB_A0State = digitalRead(WB_A0);
int WB_IO1State = digitalRead(WB_IO1);
int WB_IO2State = digitalRead(WB_IO2);
Serial.println(WB_A0State);
Serial.println(WB_IO1State);
Serial.println(WB_IO2State);
Serial.println(" ");
delay(1);
Any pointers would be greatly appreciated, Thanks.
carlrowan
(Carl Rowan)
January 4, 2024, 12:17am
2
Welcome to RAK forum @SamSkjord ,
The title you put is RAK13003 but I do not see it in your message. It seems you are using RAK11310 IO pins. Can you confirm?
Regarding your question.
Can you share the circuit/schematic? Do you have any pullup resistor on the input pins?
SamSkjord
(Sam Conway)
January 4, 2024, 9:31am
3
Hi Carl, you’re correct! updated the title.
Rough sketch below, I haven’t added any pullups as I believed
did this internally?
carlrowan
(Carl Rowan)
January 4, 2024, 9:48am
4
Hi @SamSkjord ,
I haven’t looked deeper on RP2040 and Arduino Mbed port but you can try to enable an internal pullup using this pinMode(WB_A0, INPUT_PULLUP);
If this doesn’t work, you will need an external pull up so that the pins are not left floating.
SamSkjord
(Sam Conway)
January 4, 2024, 9:53am
5
That works perfectly now, thanks for your help
Refer to the RAK11310 documentation to ensure that you are using the correct methods for reading digital inputs. Sometimes, specific modules may have unique requi rements.
system
(system)
Closed
January 15, 2024, 3:39pm
7
