Hi all!! Can anybody help me with Senseair S8? This is CO2 sensor with UART communication. I have RAK19001 and RAK11310, sensor connected to RXD1/TXD1 pin of the board.
Below is an example code from the library. How can I adapt this code for RAK19001 + RAK11310?
Maybe you have an example that works with Senseair S8?
Get CO2 value
#include <Arduino.h>
#include “s8_uart.h”
/* BEGIN CONFIGURATION */
#define DEBUG_BAUDRATE 115200
#if (defined USE_SOFTWARE_SERIAL || defined ARDUINO_ARCH_RP2040)
#define S8_RX_PIN 5 // Rx pin which the S8 Tx pin is attached to (change if it is needed)
#define S8_TX_PIN 4 // Tx pin which the S8 Rx pin is attached to (change if it is needed)
#else
#define S8_UART_PORT 1 // Change UART port if it is needed
#endif
/* END CONFIGURATION */
#ifdef USE_SOFTWARE_SERIAL
SoftwareSerial S8_serial(S8_RX_PIN, S8_TX_PIN);
#else
#if defined(ARDUINO_ARCH_RP2040)
REDIRECT_STDOUT_TO(Serial) // to use printf (Serial.printf not supported)
UART S8_serial(S8_TX_PIN, S8_RX_PIN, NC, NC);
#else
HardwareSerial S8_serial(S8_UART_PORT);
#endif
#endif
S8_UART *sensor_S8;
S8_sensor sensor;
void setup() {
// Configure serial port, we need it for debug
Serial.begin(DEBUG_BAUDRATE);
// Wait port is open or timeout
int i = 0;
while (!Serial && i < 50) {
delay(10);
i++;
// First message, we are alive
Serial.println("");
Serial.println(“Init”);
// Initialize S8 sensor
S8_serial.begin(S8_BAUDRATE);
sensor_S8 = new S8_UART(S8_serial);
// Check if S8 is available
sensor_S8->get_firmware_version(sensor.firm_version);
int len = strlen(sensor.firm_version);
if (len == 0) {
Serial.println(“SenseAir S8 CO2 sensor not found!”);
while (1) { delay(1); };
// Show basic S8 sensor info
Serial.println(">>> SenseAir S8 NDIR CO2 sensor <<<");
printf(“Firmware version: %s\n”, sensor.firm_version);
sensor.sensor_id = sensor_S8->get_sensor_ID();
Serial.print(“Sensor ID: 0x”); printIntToHex(sensor.sensor_id, 4); Serial.println("");
Serial.println(“Setup done!”);
Serial.flush();
void loop() {
//printf(“Millis: %lu\n”, millis());
// Get CO2 measure
sensor.co2 = sensor_S8->get_co2();
printf(“CO2 value = %d ppm\n”, sensor.co2);
//Serial.printf("/%u/\n", sensor.co2); // Format to use with Serial Studio program
// Compare with PWM output
//sensor.pwm_output = sensor_S8->get_PWM_output();
//printf(“PWM output = %0.0f ppm\n”, (sensor.pwm_output / 16383.0) * 2000.0);
// Wait 5 second for next measure
delay(5000);
