I want to know whether it’s possible to connect the Breakout Board with ESP32?
Welcome to the forum @razarahil
You can connect the ESP32 with one of it’s UARTS to UART0_TX and UART0_RX of the RAK11720.
Then you can control the RAK11720 with AT commands from the ESP32.
I tried the basic AT command, but no responsewas received. I’ve connected the 3v3 and gnd on the right-hand side where the UART0 pins are located.
My code:
#include <Arduino.h>
// Define UART pins for the RAK module (adjust according to your wiring)
#define RAK_RX_PIN 16 // Pin on ESP32C6 used for receiving data (connected to RAK TX)
#define RAK_TX_PIN 17 // Pin on ESP32C6 used for transmitting data (connected to RAK RX)
void setup() {
// Start the Serial Monitor for debugging
while (!Serial); // Wait for the Serial Monitor to be available
// Initialize a second hardware serial port for the RAK module
// Using Serial1 with specified RX and TX pins
Serial1.begin(115200, SERIAL_8N1, RAK_RX_PIN, RAK_TX_PIN);
delay(2000); // Allow some time for the module to initialize
Serial.println("Sending AT command to RAK module...");
Serial1.println("AT"); // Send the basic AT command
void loop() {
// Check if data is available from the RAK module
if (Serial1.available()) {
String response = Serial1.readStringUntil('\n');
Serial.print("Module Response: ");
Serial.println(response);
// Optionally, you could resend the AT command periodically if needed:
// delay(5000);
// Serial1.println("AT");
Did you cross RX and TX lines?
RX RAK11720 <==> TX ESP32
TX RAK11720 <==> RX ESP32
Did you try connecting a computer to the RAK11720 with a terminal app and check that it responds to AT commands?
Yes, I’ve crossed check but still not responding.
I tried with Putty command and it’s responded to AT command.
Then you have to check your serial setup in the ESP32
115200 Baud, 8 bit, no parity, 1 stop bit
AT commands must be ending with CR/LF
