Hello there,
Iam using the RAK11720 module and i was wondering if this support the use of several threads.
I want to update a display in a different thread then the rest of my code, is this possible? so yes how can i do this?
Kind regards,
Marnick
Hello there,
Kind regards,
Marnick
Are you using RUI3? Then there are no “threads” or tasks. At least not from API level.
It might be different if you use Ambiq Apollo3 SDK with FreeRTOS directly to write your application.
Oke Thankyou,
Do you also have ideas for creating a higher SPI speed? I have a ili9341 tft display and the refresh time is real slow. I tried to set the SPI speed to 10Mhz and 25 Mhz but this doesnt have any effect.
Kind regards,
Marnick
I tried to use the adafruit ili9341 library with the ili9341 tft display but the display only works via software SPI and not hardware SPI, which is very slow.
Iam now at a point that i cant use the RAK11720 on my product anymore if my display is not working properly. Do you have any suggestion to make the display run faster?
