wilgaced
(Wilkins Cedano)
February 1, 2024, 12:45am
1
I Am trying to register bluetooth callback with RUI3 API but the callback never call what doing wrong?
the idea is, if device connect to RAK11720 call the bleCallback
void bleCallback(Event event)
Serial.printf(" Bluetooth testing callBack... %c \r\n", event);
void setup()
// Start BLE UART advertisement for ever
api.ble.settings.blemode(RAK_BLE_UART_MODE);
api.ble.advertise.start(0);
api.ble.registerCallback(BLE_CONNECTED, (BLE_HANDLER) bleCallback);
beegee
(Bernd Giesecke)
February 1, 2024, 2:33am
2
What RUI3 version are you using?
I tried the latest staging RUI3 V4.1.1 with this code in setup() :
MYLOG("SETUP", "Starting BLE");
Serial6.begin(115200, RAK_AT_MODE);
api.ble.advertise.start(30);
api.ble.registerCallback(BLE_CONNECTED, (BLE_HANDLER)bleCallback);
with the callback
void bleCallback(void)
MYLOG("BLE-CB","Bluetooth testing callBack... ");
My log shows the callback
Interesting here is that event is 0, but it should be 1. Need to check with R&D.
And the BLE callback handler is defined as void bleCallback(void) Seems the event is not forwarded to the callback. Another thing to check with R&D
beegee
(Bernd Giesecke)
February 1, 2024, 4:58am
3
Figured it out.
Two callbacks required, one for connect, one for disconnect. I found if I use Serial.print() in the callback, I am getting code crashes. So I am calling another function with a timer to announce the event.
uint8_t event;
void ble_con_cb(void)
event = BLE_CONNECTED;
api.system.timer.start(RAK_TIMER_1, 100, &event);
void ble_dis_cb(void)
event = BLE_DISCONNECTED;
void setup(void)
api.ble.registerCallback(BLE_CONNECTED, (BLE_HANDLER)ble_con_cb);
api.ble.registerCallback(BLE_DISCONNECTED, (BLE_HANDLER)ble_dis_cb);
api.system.timer.create(RAK_TIMER_1, connection_handler, RAK_TIMER_ONESHOT);
void connection_handler(void *event)
uint8_t *reason = (uint8_t *)event;
if (reason != NULL)
if (reason[0] == BLE_CONNECTED)
MYLOG("BLE-CB", "Bluetooth connected...");
if (reason[0] == BLE_DISCONNECTED)
MYLOG("BLE-CB", "Bluetooth disconnected...");
return;
Works for me.
system
(system)
Closed
February 11, 2024, 2:44pm
5
