RAK11720 Zephyr OS (Power Management) Wake up from deep sleep
Hello everyone,
I am trying to implement a wake-up mechanism in my application in Zephyr OS. I have configured an interrupt on a GPIO pin triggered by the fifo overrun event of a lis3dh accelerometer. I want my application to be in sleep mode (SUSPEND_TO_RAM) for most of the time and only be awaken from the trigger of the interrupt. Hereby, it’s how every part is more or less implemented:
Overlay
pins {
		compatible = "gpio-keys";
		status = "okay";
		trigger_pin: trigger_pin {
			gpios = <&gpio32_63 6 (GPIO_ACTIVE_HIGH)>;
			label = "LIS3DH Interrupt 1";
GPIO interrupt and callback
triggerPin = GPIO_DT_SPEC_GET(TRIGGER_PIN_NODE, gpios);
    if (!gpio_is_ready_dt(&triggerPin)) {
        LOG_ERR("[LIS3DHManager] GPIO not ready");
        return -ENODEV;
    ret = gpio_pin_configure_dt(&triggerPin, GPIO_INPUT);
    if (ret != 0) {
        LOG_ERR("[LIS3DHManager] Failed to configure INT pin: %d", ret);
        return ret;
    LOG_INF("[LIS3DHManager] Linking callback to interrupt");
    ret = gpio_pin_interrupt_configure_dt(&triggerPin, GPIO_INT_EDGE_RISING | GPIO_INT_WAKEUP);
    if (ret != 0) {
        LOG_ERR("[LIS3DHManager] Failed to configure GPIO interrupt: %d", ret);
        return ret;
    ret = pm_device_wakeup_is_capable(triggerPin.port);
	if (ret != 0) {
        LOG_ERR("[LIS3DHManager] GPIO not eligible as a wake-up source: %d", ret);
        return ret;
	ret = pm_device_wakeup_enable(triggerPin.port, true);
	if (ret != 0) {
        LOG_ERR("[LIS3DHManager] GPIO wake-up source not enabled: %d", ret);
        return ret;
ps. I tried to use GPIO_INT_WAKEUP mask and PM APIs (pm_device_wakeup_enable) but it didn’t work anything
Main
int main(void)
    setup();
    #if defined(CONFIG_BT_PERIPHERAL)
        int ret = rak_ble_peripheral_init();
        if (ret) {
            LOG_ERR("Failed to init ble peripheral: %d", ret);
            return -1;
    #endif
	while(true) {
        MainApp::LIS3DHRun(LIS3DH_FIFO_MODE);
        if(accel_sample_event_counter > 2) {
            sendClassificationAndGpsData();
            accel_sample_event_counter = 0;
        k_sleep(K_FOREVER);
	return 0;
Has anyone dealt with it somehow?
