RAK12002 example codes does not works
  • What product do you wish to discuss? RAK4631, RAK3372, RAK11200, RAK11310, RAK11722?
RAK12002 with RAK4630
  • What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)?
    RUI in Arduino
  • Computer OS? (MacOS, Linux, Windows)
    Windows
  • What Computer OS version?
    Windows 11
  • Provide source code if custom firmware is used or link to example if RAKwireless example code is used.:
Source code that I used from the following link in RAK:
RAK12002 quickstart
   @file RAK12002_RTC_DateTime_RV-3028-C7.ino
   @author rakwireless.com
   @brief Set and read RTC time.
   @version 0.1
   @date 2021-04-30
   @copyright Copyright (c) 2021
#include "Melopero_RV3028.h" //Click here to get the library: http://librarymanager/All#Melopero_RV3028
Melopero_RV3028 rtc;
 * @brief Arduino setup function
 * @note Called once after power on or reset
void setup()
  time_t timeout = millis();
  while (!Serial)
      delay(100);
    else
      break;
  rtc.initDevice(); // First initialize and create the rtc device
  rtc.writeToRegister(0x35,0x00);
  rtc.writeToRegister(0x37,0xB4); //Direct Switching Mode (DSM): when VDD < VBACKUP, switchover occurs from VDD to VBACKUP
  rtc.set24HourMode();  // Set the device to use the 24hour format (default) instead of the 12 hour format
  // Set the date and time
  // year, month, weekday, date, hour, minute, second
  // Note: time is always set in 24h format
  // Note: month value ranges from 1 (Jan) to 12 (Dec)
  // Note: date value ranges from 1 to 31
  rtc.setTime(2021, 4, 6, 30, 0, 0, 0);
 * @brief Arduino loop function
 * @note Output date and time every second
void loop()
  Serial.printf("%d:%d:%d %d/%d/%d \n",rtc.getHour(),rtc.getMinute(),rtc.getSecond(),rtc.getYear(),rtc.getMonth(),rtc.getDate());
  delay(1000);
Running the exact code give us the following results:
C:\Users\Gilberto\AppData\Local\Temp\.arduinoIDE-unsaved202656-57884-1gbs2kt.wpyi\sketch_jun6c\sketch_jun6c.ino: In function 'void setup()':
C:\Users\Gilberto\AppData\Local\Temp\.arduinoIDE-unsaved202656-57884-1gbs2kt.wpyi\sketch_jun6c\sketch_jun6c.ino:35:7: error: 'class Melopero_RV3028' has no member named 'initDevice'
   35 |   rtc.initDevice(); // First initialize and create the rtc device
exit status 1
Compilation error: 'class Melopero_RV3028' has no member named 'initDevice'
I used the following code to detect the RTC in my custom PCB and this one worked properly:
#include <Wire.h>
void setup()
  Serial0.begin(115200, RAK_AT_MODE);
  delay(2000);
  Wire.begin();
  Serial0.println("RAK4630 - I2C Scanner");
  Serial0.println("------------------------------------------------------");
void loop()
  byte error, address;
  int nDevices = 0;
  Serial0.println("Scanning...");
  for (address = 1; address < 127; address++)
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial0.print("I2C device found at address 0x");
      if (address < 16) Serial0.print("0");
      Serial0.print(address, HEX);
      if (address == 0x52) Serial0.println("  <-- RV-3028-C7 RTC");
      else                 Serial0.println();
      nDevices++;
    else if (error == 4)
      Serial0.print("Unknown error at address 0x");
      Serial0.println(address, HEX);
  Serial0.println(nDevices == 0 ? "No I2C devices found" : "done");
  delay(5000);
If you read the library, it has an outdated README.
Do you have updated codes and examples?
As mentioned in the Quick Start Guides:
You can find updated examples in the WisBlock GitHub repo ==> WisBlock/examples/common/sensors at master · RAKWireless/WisBlock · GitHub
try
rtc.initI2C();
Thank you for your answer, I solved the problem.
