In the example - “The voc index can directly indicate the quality of the air. The higher the value, the worse the air quality.” But for me, the values change inverted, when I ventilate the index grows, when I tested spray it falls. Checked on two sensors - the same.
I have two RAK12047 running in my office and a Milesight Air Quality device as reference and the behaviour of the devices is as expected.
Forced ventilation could lead to more volatile organic components being blown to the sensor. Not sure what you want to achieve with “spraying”.
Keep in mind that Sensirions algorithm says it takes up to 24 hours learning time.
Maybe What is Sensirion’s VOC Index? helps.
Both sensors have been installed and working for over a week and behave the same. Generally VOC index is 235-238. I spray with a deodorant (I also tried a solvent) nearby - the index value drops to 170-180 and then slowly rises to 235. Is that how it should be? I think not, but I may be wrong.
What is the code you are using?
I guess you are using the Sensirion VOC algorithm?
What is you reading interval from the sensor?
RAK12047_SGP40_GetVOCIndex Example
120 sec
whole code
#include <Arduino.h>
#include "LoRaWan-Arduino.h" //http://librarymanager/All#SX126x
#include <SPI.h>
#include "SparkFun_SCD30_Arduino_Library.h" // Click here to get the library: http://librarymanager/All#SparkFun_SCD30
#include <SensirionI2CSgp40.h> // Click here to get the library: http://librarymanager/All#SensirionI2CSgp40
#include <stdio.h>
#include "mbed.h"
#include "rtos.h"
#include <Wire.h>
#include "SparkFun_SHTC3.h" //Click here to get the library: http://librarymanager/All#SparkFun_SHTC3
#define BUZZER_CONTROL WB_IO1
using namespace std::chrono_literals;
using namespace std::chrono;
SCD30 airSensor;
SensirionI2CSgp40 sgp40;
SHTC3 g_shtc3; // Declare an instance of the SHTC3 class
#define LORAWAN_DATERATE DR_3 /*LoRaMac datarates definition, from DR_0 to DR_5*/
#define LORAWAN_TX_POWER TX_POWER_3 /*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
DeviceClass_t g_CurrentClass = CLASS_C; /* class definition*/
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_RU864; /* Region:EU868*/
lmh_confirm g_CurrentConfirm = LMH_CONFIRMED_MSG; /* confirm/unconfirm packet definition*/
static lmh_param_t g_lora_param_init = {LORAWAN_ADR_ON, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
void lorawan_unconf_finished(void);
void lorawan_conf_finished(bool result);
static lmh_callback_t g_lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler,
lorawan_confirm_class_handler, lorawan_join_failed_handler,
lorawan_unconf_finished, lorawan_conf_finished
//OTAA keys !!!! KEYS ARE MSB !!!!
uint8_t nodeDeviceEUI[8] = {0000000000000000};
uint8_t nodeAppEUI[8] = {0000000000000000};
uint8_t nodeAppKey[16] = {0000000000000000};
// ABP keys
uint32_t nodeDevAddr = 0x260116F8;
uint8_t nodeNwsKey[16] = {0x7E, 0xAC, 0xE2, 0x55, 0xB8, 0xA5, 0xE2, 0x69, 0x91, 0x51, 0x96, 0x06, 0x47, 0x56, 0x9D, 0x23};
uint8_t nodeAppsKey[16] = {0xFB, 0xAC, 0xB6, 0x47, 0xF3, 0x58, 0x45, 0xC7, 0x50, 0x7D, 0xBF, 0x16, 0x8B, 0xA8, 0xC1, 0x7C};
// Private defination
#define LORAWAN_APP_INTERVAL 120000 /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
mbed::Ticker appTimer;
void tx_lora_periodic_handler(void);
static uint32_t count = 0;
bool send_now = false;
void errorDecoder(SHTC3_Status_TypeDef message) // The errorDecoder function prints "SHTC3_Status_TypeDef" resultsin a human-friendly way
switch (message)
case SHTC3_Status_Nominal:
Serial.print("Nominal");
break;
case SHTC3_Status_Error:
Serial.print("Error");
break;
case SHTC3_Status_CRC_Fail:
Serial.print("CRC Fail");
break;
default:
Serial.print("Unknown return code");
break;
void setup()
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
// Initialize LoRa chip.
lora_rak11300_init();
Serial.println("Welcome to RAK11300 LoRaWan!!!");
if (doOTAA)
Serial.println("Type: OTAA");
else
Serial.println("Type: ABP");
switch (g_CurrentRegion)
case LORAMAC_REGION_AS923:
break;
case LORAMAC_REGION_AU915:
break;
case LORAMAC_REGION_CN470:
break;
case LORAMAC_REGION_CN779:
Serial.println("Region: CN779");
break;
case LORAMAC_REGION_EU433:
break;
case LORAMAC_REGION_IN865:
break;
case LORAMAC_REGION_EU868:
break;
case LORAMAC_REGION_KR920:
break;
case LORAMAC_REGION_US915:
break;
case LORAMAC_REGION_RU864:
Serial.println("Region: RU864");
break;
case LORAMAC_REGION_AS923_2:
Serial.println("Region: AS923-2");
break;
case LORAMAC_REGION_AS923_3:
Serial.println("Region: AS923-3");
break;
case LORAMAC_REGION_AS923_4:
Serial.println("Region: AS923-4");
break;
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
// Initialize LoRaWan
uint32_t err_code = lmh_init(&g_lora_callbacks, g_lora_param_init, doOTAA, g_CurrentClass, g_CurrentRegion);
if (err_code != 0)
return;
// Start Join procedure
lmh_join();
uint16_t error;
char errorMessage[256];
uint16_t serialNumber[3];
uint8_t serialNumberSize = 3;
// pinMode(WB_IO2, OUTPUT);
// digitalWrite(WB_IO2, HIGH);
pinMode(BUZZER_CONTROL,OUTPUT);
delay(1000);
Wire.begin();
sgp40.begin(Wire);
error = sgp40.getSerialNumber(serialNumber, serialNumberSize);
if (error)
Serial.print("Error trying to execute getSerialNumber(): ");
errorToString(error, errorMessage, 256);
Serial.println(errorMessage);
else
Serial.print("Serial Number:");
Serial.print("0x");
for (size_t i = 0; i < serialNumberSize; i++)
uint16_t value = serialNumber[i];
Serial.print(value < 4096 ? "0" : "");
Serial.print(value < 256 ? "0" : "");
Serial.print(value < 16 ? "0" : "");
Serial.print(value, HEX);
Serial.println();
uint16_t testResult;
error = sgp40.executeSelfTest(testResult);
if (error)
Serial.print("Error trying to execute executeSelfTest(): ");
else if (testResult != 0xD400)
Serial.print("executeSelfTest failed with error: ");
Serial.println(testResult);
//Start sensor using the Wire port and enable the auto-calibration (ASC)
if (airSensor.begin(Wire, true) == false)
Serial.println("Air sensor not detected. Please check wiring. Freezing...");
while (1)
delay(10);
Serial.print("Automatic self-calibration set to:");
if (airSensor.getAutoSelfCalibration() == true)
Serial.println("true");
else
Serial.println("false");
Serial.println("shtc3 init");
Serial.print("Beginning sensor. Result = "); // Most SHTC3 functions return a variable of the type "SHTC3_Status_TypeDef" to indicate the status of their execution
errorDecoder(g_shtc3.begin()); // To start the sensor you must call "begin()", the default settings use Wire (default Arduino I2C port)
Wire.setClock(400000); // The sensor is listed to work up to 1 MHz I2C speed, but the I2C clock speed is global for all sensors on that bus so using 400kHz or 100kHz is recommended
Serial.println();
if (g_shtc3.passIDcrc) // Whenever data is received the associated checksum is calculated and verified so you can be sure the data is true
{ // The checksum pass indicators are: passIDcrc, passRHcrc, and passTcrc for the ID, RH, and T readings respectively
Serial.print("ID Passed Checksum. ");
Serial.print("Device ID: 0b");
Serial.println(g_shtc3.ID, BIN); // The 16-bit device ID can be accessed as a member variable of the object
else
Serial.println("ID Checksum Failed. ");
void loop()
// Every LORAWAN_APP_INTERVAL milliseconds send_now will be set
// true by the application timer and collects and sends the data
if (send_now)
send_now = false;
send_lora_frame();
/**@brief LoRa function for handling HasJoined event.
if (doOTAA == true)
else
Serial.println("ABP Mode");
if (ret == LMH_SUCCESS)
delay(1000);
// Start the application timer. Time has to be in microseconds
appTimer.attach(tx_lora_periodic_handler, (std::chrono::microseconds)(LORAWAN_APP_INTERVAL * 1000));
@param[in] app_data Pointer to rx data
uint8_t siren_command = *app_data->buffer;
if(siren_command==0)
Serial.println("0 Siren OFF");
noTone (BUZZER_CONTROL);
if(siren_command==1)
Serial.println("1 Siren ON");
for (int x = 0; x < 100; x++)
tone(BUZZER_CONTROL, 1000);
delay(300);
tone(BUZZER_CONTROL, 200);
delay(300);
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, g_CurrentConfirm);
Serial.println("TX finished");
Serial.printf("Confirmed TX %s\n", result ? "success" : "failed");
//Not joined, try again later
return;
collect_data();
if (error == LMH_SUCCESS)
count++;
else
count_fail++;
String data = "";
void collect_data()
float Temperature = 0;
float Humidity = 0;
g_shtc3.update();
if (g_shtc3.lastStatus == SHTC3_Status_Nominal) // You can also assess the status of the last command by checking the ".lastStatus" member of the object
Temperature = g_shtc3.toDegC(); // Packing LoRa data
Humidity = g_shtc3.toPercent();
Serial.print("RH = ");
Serial.print(g_shtc3.toPercent()); // "toPercent" returns the percent humidity as a floating point number
Serial.print("% (checksum: ");
if (g_shtc3.passRHcrc) // Like "passIDcrc" this is true when the RH value is valid from the sensor (but not necessarily up-to-date in terms of time)
Serial.print("pass");
else
Serial.print("fail");
Serial.print("), T = ");
Serial.print(g_shtc3.toDegC()); // "toDegF" and "toDegC" return the temperature as a flaoting point number in deg F and deg C respectively
Serial.print(" deg C (checksum: ");
if (g_shtc3.passTcrc) // Like "passIDcrc" this is true when the T value is valid from the sensor (but not necessarily up-to-date in terms of time)
else
Serial.println(")");
else
Serial.print("Update failed, error: ");
errorDecoder(g_shtc3.lastStatus);
Serial.println();
uint16_t error;
uint16_t srawVoc = 0;
float vocIndex = 0;
* @brief Set the relative humidity and temperature in the current environment.
* Temperature and humidity calibration has been performed inside the sensor.
* RH/ticks=RH/%×65535/100
* T/ticks=(T/°C + 45)×65535/175
uint16_t defaultRh = 0x8000; // 50 %RH
uint16_t defaultT = 0x6666; // 25 ℃
delay(1000);
error = sgp40.measureRawSignal(defaultRh, defaultT, srawVoc);
if (error)
Serial.print("Error trying to execute measureRawSignal(): ");
else
Serial.print("SRAW_VOC:");
Serial.print(srawVoc);
vocIndex = (float)srawVoc/131.07 ;
/* VOC index.
* The voc index can directly indicate the quality of the air. The higher the value, the worse the air quality.
* 0-100,no need to ventilate,purify.
* 100-200,no need to ventilate,purify.
* 200-400,ventilate,purify.
* 400-500,ventilate,purify intensely.
Serial.print(" VOC Index:");
Serial.println(vocIndex);
uint16_t co2;
double temp;
double hum;
uint16_t voci = vocIndex;
if (airSensor.dataAvailable())
co2 = airSensor.getCO2();
temp = airSensor.getTemperature();
hum = airSensor.getHumidity();
else
Serial.println("Waiting for new data");
data = "Tem:" + String(temp) + "C " + "Hum:" + String(hum) + "% " + "CO2: " + String(co2) + "ppm" + "VOC Index " + String(voci);
Serial.println(data);
uint32_t i = 0;
uint16_t t = Temperature * 100;
uint16_t h = Humidity * 100;
uint32_t c = co2 * 100;
uint32_t v = voci * 100;
//result: T=28.25C, RH=50.00%, P=958.57hPa, G=100406 Ohms
m_lora_app_data.buffer[i++] = 0x01;
m_lora_app_data.buffer[i++] = (uint8_t)(t >> 8);
m_lora_app_data.buffer[i++] = (uint8_t)t;
m_lora_app_data.buffer[i++] = (uint8_t)(h >> 8);
m_lora_app_data.buffer[i++] = (uint8_t)h;
m_lora_app_data.buffer[i++] = (uint8_t)((c & 0xFF000000) >> 24);
m_lora_app_data.buffer[i++] = (uint8_t)((c & 0x00FF0000) >> 16);
m_lora_app_data.buffer[i++] = (uint8_t)((c & 0x0000FF00) >> 8);
m_lora_app_data.buffer[i++] = (uint8_t)(c & 0x000000FF);
m_lora_app_data.buffer[i++] = (uint8_t)((v & 0xFF000000) >> 24);
m_lora_app_data.buffer[i++] = (uint8_t)((v & 0x00FF0000) >> 16);
m_lora_app_data.buffer[i++] = (uint8_t)((v & 0x0000FF00) >> 8);
m_lora_app_data.buffer[i++] = (uint8_t)(v & 0x000000FF);
m_lora_app_data.buffsize = i;
/**@brief Function for handling user timerout event.
// This is a timer interrupt, do not do lengthy things here. Signal the loop() instead
send_now = true;
That is not the best way to use the VOC sensor. It is just a very simple code to show how to read from the sensor.
Have a look at this code for RAK12047
Using the Sensirion VOC Gas Index Algorithm will get you better results.
thanks, I’ll try
for the CO2 sensor, maybe there are also more correct methods?
Another remark for the RAk12047, the first 100 values coming out of the Sensirion algorithm should not be trusted.
I actually throw them away in my code.
Hi Bernd.
I don’t have RUI3 and unfortunately my experience is not enough to apply this:
for RAK11310. Do you have the same example code for RAK11310?
thanks in advance
This RAK12047_voc.cpp code example is written for RAK4631, RAK11200 and RAK11310, but no 100% guarantee that it works without problems on the RAK11310.
I don’t like Mbed and because of that I am not using the RAK11310 much.
