I’ve run into a strange issue when sending messages over CAN bus.
When I run the example code from RAK13006_CAN_Master.ino it
- sends 48 frames successfully (frames 1-48)
- fails to send all additional frames (frames 49+)
I have tried using different CAN bit rates and different messages, but the result is the same. Only 48 frames are successfully sent. Never more, never less. Exactly 48 succeed.
I’m using
- WisBlock Base: Rak19011
- WisBlock Core: RAK11200
- WisBlock Power Module: RAK19012
- WisBlock IO Slot A: RAK5802 (Modbus)
- WisBlock IO Slot B: RAK13006 (CAN Bus)
Any ideas what might cause this?
Thanks for your help
I added this issue to the example code Github repo as well for additional visibility
