RAK14015 button
I’m working on getting the RAK14015 button to work on Meshtastic. (From the Field Tester).
It looks like it should just be simply connected to WB_IO5 (RAK4631), but this doesn’t seem to be operable.
Welcome to RAK forum @no_more_mondays ,
What issue do you encounter with the user button?
I tested the RAK10701 with Meshtastic (I replaced the RAK4631 inside it since Field Tester is based on RUI3) and the button seems to work fine.
Here’s the serial/terminal feedback on user button double-click.
It was a conflict with the display driver (eTFT). It used pin 9 as the RST pin and once that was removed everything started working.
