I’m using the EEPROM module together with some other modules: Flash RAK15001, Environment RAK1906, RTC RAK12002. However, it is working energizing a different IO pin than it should. for instance, the EEPROM module is connected in the slot D (which has the IO5 and IO6 pins in the RAK19001), but if the IO6 is set to high, doesn’t work at all. But, if the IO2 pin is set to high, works normally. How is this possible, as the module is connected in the slot D, and the IO2 pin is only available for slots A and B in that board?
I’m not sure I completely understood the answer. The module that is not working properly is the RAK 15000 EEPROM, not the 15001 Flash. I’m aware that the RAK15001 doesn’t use the WB_IO2. However, it is necessary for the RAK15000 depending on the slot that is connected.
