Looking to connect a second USB port via the header pins on the RAK19001. Not sure what pins I would need to connect to be able to charge and send data to the core. I’ve been trying to match the type c usb port pinout names to the core IO pin names and not finding matches for all of them. Looking to use a 5 pin pcb mounted Amphenol MUSB-K152-30.
Huge noob so thank you in advance for any insight anyone can give.
Thanks Carl! When looking at the diagram of the PCB mounted device I think D+ and D- would correspond to the USB headers. I’m not sure what ID would connect to though.
Hi @carlrowan, do I need to configure anything in the device to be able to use these header pins? Or should I be able to pass data through the USB pins after connecting?
