Trying to make a meshtastic basestation, ESP32 and ethernet. Will this pinout work?
Welcome to the forum @deFRAGer
No, it will not work.
Both the RAK13300 LoRa module and the RAK13600 Ethernet module are using the SPI and sharing the same NSS (select) pin.
And both are using IO3 and IO6.
If you do not need the WiFi, the combination of RAK4631 and RAK13800 Ethernet could work.
Sadly, meshtastic doesn’t support HTTP on any MCU other than the ESP32, which was the primary purpose for purchasing these components (wanting to use ethernet rather than WiFi). Thanks for the quick response, I’ve put through an order cancellation request ![]()
