Im wondering if full batt+solar plugs in the rak19003 should work with mashtastic firmware?
I have a rak19003 board that has a 4630 module in it, running meshtastic. I have a 3.7v lithium battery, 3000mah, plugged into the BATT, verifying polarity as per the diagram in the user manual where GND is the pin closest to the edge of the board.
With the USB connected, everything works, even get this on the serial port:
DEBUG | ??:??:?? 606 [Power] Battery: usbPower=1, isCharging=1, batMv=3996, batPct=81
But if I unplug the USB everything seemengly dies; if i then unplug the batt and plug it back in then the greed led (different led than the red) comes on for a few secs then turns off. I can RST and the process starts back over. A double RST has the green LED pulsating.
The red led never does a thing through this process after the USB is removed.
Even with the green LED off (and the red off) I can use a flipperzero and DAP and pyocd to query it, so it does seem to be alive:
Thanks all - now, I have this when connected to the USB serial port when I do AT+VER=?:
RUI_4.1.1_RAK4631
its a firmware that I found to load on it to revert from meshtastic, not sure it it was the right one for myRAK19003 with the RAK4630 (which shows up on USB as a RAK4631)
I cannot tell from the silkscreen if its a revB or E, the right is cut off, but my UART pads there are labeled TX0, RX0 if that helps, so prob an E? It was ordered Jan 22 2024 if that helps?
But how to " Also confirm the board is set to the RAK19003 variant"?
I tried to use UART-bridge on the flipper to get onto the UART but cannot get any response.
Meshtastic is based on the Arduino/PlatformIO BSP’s using the Arduino SDK.
RUI3 SDK is Arduino compatible, but it is not compatible with Meshtastic.
One of many differences is the bootloader. You cannot flash an application compiled with Arduino/PlatformIO BSP on a device with RUI3 bootloader. And vice versa.
