does RAK19003 works with GPS (RAK12500) over I2C on Slot A also?
could not find pinout for it to test.
great, where could I found the I2C pins to define them over VSCODE?
for RAK19007+RAK4631 i used:
Wire.setPins(Board_SDA, Board_SCL);
Wire.begin();
with:
#define Board_SDA 13
#define Board_SCL 14
Hi @richonguzman ,
If you are using Arduino extension on VSCODE, it is be on the variants.h file. If you are using platformIO, it should be the same but I am not sure on the structure of packages in PIO. @beegee mostly use platformIO. He can help in case you use PIO.
Just use Wire.begin(). No need to define the pins. It will use the correct ones automatically.
thanks a lot, find a Ham Op who has it and will test the code to confirm also ![]()
Confirmed
RAK19007 and RAK19003 work the same with Wire.begin() to recognize gps
RAK19007 uses Slot A, RAK19003 uses Slot C
